Dear Community,
I have 2 identical HP switches in 1 cabinet under each other phy-n501 and phy-n502.
both are equally warm but Phy-n502 continues to give warning in librenms that it is above 30 degrees. Phy-n501 does not start until it is above 34 grade.
Even on the switch itself, the warning does not exceed 35 degrees.
my question is how can I solve this? and how is it possible that 2 different temperature warning points are involved in 2 same switches
extra information:
Alert : [Sensor over limit - Check Device Health Settings]
System Information:
System Name: phy-n002
Hardware; J8692A Switch 3500yl-24G
Operating System: HP ProCurve K.16.02.0025
System Name: phy-n501
Hardware: J8692A Switch 3500yl-24G
System temperature:
./validate.php
| LibreNMS | 1.47-44-g29f8a8d4a |
| DB Schema | 281 |
| PHP | 7.2.10-0ubuntu0.18.04.1 |
| MySQL | 10.1.34-MariaDB-0ubuntu0.18.04.1 |
| RRDTool | 1.7.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.0
