Expanded Eltek Smartpack R Sensor Coverage
We’re using LNMS to monitor Eltek Smartpack R power systems.
Currently, LibreNMS only bring in limited number of sensors from these devices.
The Smartpack S and R systems expose many parameters via SNMP (e.g., battery health, load current, rectifier temperatures), but LibreNMS seems to only pick up a subset of these sensors.
This limits our ability to fully monitor system health and performance
Down below you see some of the data that we’re missing and hope to be able to add.
.1.3.6.1.4.1.12148.10.10.23.2.0 (Ah Charged) - .1.3.6.1.4.1.12148.10.10.23.5.0 (Value)
.1.3.6.1.4.1.12148.10.10.24.2.0 (Ah Discharged) - .1.3.6.1.4.1.12148.10.10.24.5.0 (Value)
.1.3.6.1.4.1.12148.10.10.11.2.0 (Total Capacity - Battery) - .1.3.6.1.4.1.12148.10.10.11.5.0 (Value)
.1.3.6.1.4.1.12148.10.10.9.2.0 (Rest Capacity - Battery - .1.3.6.1.4.1.12148.10.10.9.5.0 (Value)
.1.3.6.1.4.1.12148.10.10.10.2.0 (Used Capacity - Battery) - .1.3.6.1.4.1.12148.10.10.10.4.0 (Value)
.1.3.6.1.4.1.12148.10.10.12.2.0 (Quality - Battery) - .1.3.6.1.4.1.12148.10.10.12.4.0 (Value)
.1.3.6.1.4.1.12148.10.10.2.0 (Type of Battery, Return string)
Having access to all available sensors would improve alerting, capacity planning, and preventive maintenance. It would also benefit other users running the same hardware.
Discovery: Source Code | 2syaz | Rocket Powered Pastebin
Device Poll: Source Code | uEOaR | Rocket Powered Pastebin
SNMPBulkWalk: https://paste.rs/TXuMw.txt
