Could be possible to add an option of generate report or export to csv, for inventory, devices lists, arp or fdb table… ?
I have seen a export to csv option in ports menu but nowhere else.
Thanks in advance.
Thanks in advance.
If you don’t mind using custom script to generate required output - it is possible with REST API, so you just get from api all required data, then filter/format it and output any way you like
I am doing queries directly to database but it would be better to have an export, and a report module for the inentory purposes.
thanks.
