Exporting to CSV does not take filters into account
I’m using last version 26.1.1 and I’m having trouble with CSV exports. They’re not taking the filter into account!
Example with Overview/Inventory, URL called when clicking “Export page” even though a filter is applied to the device : https://librenms.chrul.net/ajax/table/inventory/export?current=1&rowCount=50&sort[device]=asc
The device ID isn’t being transmitted! What could be causing this?
Can you help me?
Same problem here with filtering port lists.
This has worked last year but seems to be broken now. The resulting export is apparently a random list of ports instead of the filtered ones.
Same here :slight_smile:
