Hi people,
I am fairly new to this community, so I just start to find my way here.
I just added a few AP305C’s to LibreNMS and some of them are identified as Generic device. I noticed the difference in model type:
iso.3.6.1.2.1.1.1.0 = STRING: “AP305C-1, HiveOS 10.5r4 build-278788”
iso.3.6.1.2.1.1.1.0 = STRING: “AP305C, HiveOS 10.5r5 build-279185”
The AP305C is doing fine within LibreNMS, but the AP305C-1 is identified as Generic. How can I get this solved?
Thanks!
Regards,
Mike
In addition I also am very curious about how LibreNMS discovers and classify the device as the type it is. Then I will probably understand why the 305C is detected as Wireless AP and the 305C-1 as generic. I did not find any templates or files for modification that describe the specific devices.
Any suggestions please?
Thanks!
Regards,
Mike
Have you checked out:
Could possibly be the following definition, we would have to see the poller output to sure sure though…
os: hiveos-wireless
text: 'Aerohive HiveOS'
type: wireless
icon: aerohive
mib_dir: aerohive
over:
- { graph: device_bits, text: Traffic }
- { graph: device_processor, text: 'CPU Usage' }
- { graph: device_wireless_clients, text: 'Wifi Clients' }
discovery:
sysDescr_regex:
- '/^(Hive)*AP[\w]+(?:_n)?, HiveOS/'
Hi Slashdoom,
Thanks for your input, it is really appreciated.
I ran the poller on both the AP305C and the AP305C-1:
AP305C:
./poller.php -h 172.x.x.x
LibreNMS Poller
Starting polling run:
Hostname: 172.x.x.x
Device ID: 17
OS: hiveos-wireless
(output omitted)
AP305C-1:
LibreNMS Poller
Hostname: 172.x.x.x
Device ID: 22
OS: generic
(output omitted)
So if I understand you correctly, the sysDescr_regex should be adjusted to also match the name ‘AP305C-1’?
Regards,
Mike
I asked Chat GPT to match the expressions:
Therefore, the regular expression /^(Hive)*AP[\w]+(?:_n)?, HiveOS/ successfully matches the input string “AP305C”.
Therefore, the regular expression /^(Hive)*AP[\w]+(?:_n)?, HiveOS/ does not match the input string “AP305C-1”.
So we are getting close
Damn, I got it! The regex adjusted to also match ‘-1’ and it works now!
Original regex: ‘/^(Hive)*AP[\w]+(?:_n)?, HiveOS/’
Custom regex: ‘/^(Hive)*AP[\w\-]+(?:_n)?, HiveOS/’
Very nice. Credits to Slashdoom for pointing me in the right direction!
Good stuff. If you’re able to submit that modified definition file as a pull request on GitHub you’ll be able to help others and also be sure your change doesn’t get overwritten by updates.
Yes, I have submitted a pull request.
Thanks again!
system
Closed
30 May 2023 12:11
9
