Hi Guys,
I have BIG-IP in my LibreNMS, the problem here is ,
1, I want create alert, if there is a LTM POOL is down, what are the Entity to monitor ?
2. I want create alert, if there is a LTM NODE is down, what are the Entity to monitor ?
Thanks.
Hi Guys,
Thanks.
The component
table is where things should be, browse around this in a mysql client and see what you can come up with - ask and show what you’ve done and someone might be able to help further.
