I’ve been trying to figure this out without asking for help but my head hurts so reaching out since I feel its probably something simple.
GOAL
If os = f5 then include in email alerts
Sync Status & whether its Active or Standby
REFERENCE
HA Sync Status
sensor_class = state
sensor_oid = .1.3.6.1.4.1.3375.2.1.14.1.1.0
sensor_type = sysCmSyncStatusId
sensor_descr = sysCmSyncStatusId.0
sensor_current = 3
Closest I could come to this is:
#{{ $key }}: {{ $value[‘string’] }}
@endforeach
@endif
which produced
sensor_oid = .1.3.6.1.4.1.3375.2.1.14.1.1.0; sensor_descr = sysCmSyncStatusId.0; state_descr = syncDisconnected;
Failover Status: ACTIVE
sensor_oid = .1.3.6.1.4.1.3375.2.1.14.3.1.0
sensor_type = sysCmFailoverStatusId
sensor_descr = sysCmFailoverStatusId.active
sensor_current = 4
Have not had any luck getting this displayed on my emails (is the box Active or Standby)
Failover Status: STANDBY
sensor_descr = sysCmFailoverStatusId.standby
sensor_current = 3
More info for the F5 HA Sync Status
HA Sync STATUS
devices.os = “f5” AND sensors.sensor_type = “sysCmSyncStatusId” AND sensors.sensor_current = 0
sensors.sensor_current (3 = InSync)
SYNTAX INTEGER {
unknown(0),
syncing(1),
needManualSync(2),
inSync(3),
syncFailed(4),
syncDisconnected(5),
standalone(6),
awaitingInitialSync(7),
incompatibleVersion(8),
partialSync(9)
I don’t have the Active/Standby info since I have been focusing so much on sync status
