[FAIL] Both Dispatcher Service and Python Wrapper were active recently, this could cause double polling
Since a few days ago, when I make ./validate I get the error in the title of the post.
I have not changed any configuration. I don’t know if it is due to some update and how serious it is. How can I fix it?
-bash-4.2$ ./validate.php
LibreNMS  | 22.7.0-60-g7b3a6250f
DB Schema | 2022_07_03_1947_add_app_data (244)
PHP       | 8.1.9
Python    | 3.6.12
Database  | MariaDB 10.4.14-MariaDB
RRDTool   | 1.4.9
SNMP      | 5.7.2
[OK]    Composer Version: 2.3.10
[OK]
[OK]    MySQl and PHP time match
[OK]    Redis is functional
[OK]    rrd_dir is writable
Thanks, regards
Same issue for me.
I’ve disabled the cron line who call services wrapped but without success…
I don’t know where are the issue.
I see under my services page all the services are in critical state. If I check the logs i see services come OK at /5 minutes but after 2 seconds all comes in critical.
I think this is correlated to the FAIL
help us :slight_smile:
I see.
but when I stop the dispatcher service I’ve the same validating issues
There is a 5 minute or more delay from changes to when it is reflected.
you be right :slight_smile:
I was rushed
thank you
