[FAIL] Missing PHP extension: mysqlnd [FIX] Please install mysqlnd
You need to install php mysqlnd. Check the install docs for your distro to see what package to install
I’ve attempted the install - I’m currently running CentOS7. The command I used is “yum install php-msqlnd” and restarted the server afterwards. When I initiate .\validate.php it still gives me the message to install mysqlnd
@Knighte77
What php are you running? You didnt included your ./validate.php output.
Found the fix…
I ran yum swap php72w-mysql php72w-mysqlnd and it resolved the error in shell.
Here’s the output of my ./validate.php
[root@SL-LibreNMS librenms]# ./validate.php
LibreNMS 1.42.01-69-gd46f300
DB Schema 260
PHP 7.2.8
MySQL 5.5.60-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.7.2
Thanks that fixed it for me too on Centos 7
Thx, but that one-liner is not enough for me. I’ll try this solution from @dagbdagb next.
Thanks. It is fixed.
the yum swap command also worked for me
I’m seeing this issue on my system as well, but am unable to successfully swap mysqlnd due to composer dependencies.
[root@utlibrenms librenms]# ./validate.php
LibreNMS 1.47-22-gdef8b3e
DB Schema 279
PHP 7.2.2
MySQL 5.5.56-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.8.0
I Tried running “[root@utlibrenms librenms]# yum swap php72w-mysql php72w-mysqlnd”. Here are some highlights:
Package php72w-mysqlnd is obsoleted by php-mysqlnd, trying to install php-mysqlnd-7.2.14-1.el7.remi.x86_64 instead
Package php-common.x86_64 0:7.2.14-1.el7.remi will be obsoleting
Error: Package: composer-1.8.0-1.el7.noarch (@epel)
Requires: php-zip
Removing: php72w-common-7.2.2-1.w7.x86_64 (@webtatic)
php-zip
Obsoleted By: php-common-7.2.14-1.el7.remi.x86_64 (remi-php72)
Not found
So short story seems to be php-common is obsoleting any of the php packages that contain php-zip, which is required by composer. Is there a way around this without breaking the functionality of the systems? Librenms does appear to be functioning, despite the validation error. Thank you much.
