FAIL: No active polling method detected and FAIL: Python wrapper cron entry is not present
Hello All,
Installed Librenms today for the first time on Alma Linux 8 however after installing and running vaildate.php I an getting two errors:- no active polling method detected and python wrapper cron entry is not present. Below is the output of discovery.php and validate.php
https://p.libren.ms/view/efcf99b9
https://p.libren.ms/view/e3d77ae4
Has anyone come across this issue before and appreciate any assistance in getting this issue resolved?
Do you have working graphs?
If not, make sure you have a cron actually installed. Might be vixie-cron for Alma, I can’t remember.
I think I can pull raphs from the loaclhost that librenms is installed on 127.0.0.1. I will check regarding cron
Ok so turned out to be file permission issue on librenms cron file that was copied into /etc/cron.d fixed with command chmod 644 librenms
