My LibreNMS was also affected by that bug and the new release solved the problem however that new version bring another problem on my LibreNMS VM :
2024-09-10 14:01:24,082 :: CRITICAL :: DB Connection exception (1062, “Duplicate entry ‘librenms’ for key ‘pollers_poller_name_unique’”)
I checked on within the LibreNMS DB and I don’t see something suspicious
The output of./validate looks correct :
| LibreNMS | 24.8.0-62-g77fa7573c (2024-09-10T07:59:20+00:00) |
| DB Schema | 2024_08_27_182000_ports_statistics_table_rev_length (299) |
| PHP | 8.1.23 |
| Python | 3.8.10 |
| Database | MariaDB 10.3.39-MariaDB-0ubuntu0.20.04.2 |
| RRDTool | 1.7.2 |
| SNMP | 5.8 |
[OK] Composer Version: 2.7.9
[OK] Dispatcher Service has been used, but not recently
And from the DB :
MariaDB [librenms]> explain pollers;
| Field | Type | Null | Key | Default | Extra |
| id | int(10) unsigned | NO | PRI | NULL | auto_increment |
| poller_name | varchar(255) | NO | UNI | NULL | |
| last_polled | datetime | NO | | NULL | |
| devices | int(10) unsigned | NO | | NULL | |
| time_taken | double | NO | | NULL | |
5 rows in set (0.001 sec)
MariaDB [librenms]> select * from pollers;
| id | poller_name | last_polled | devices | time_taken |
| 1 | librenms | 2024-09-10 14:01:24 | 65 | 81 |
1 row in set (0.000 sec)
I looked at the past logs but this error started to popup with this new release, if someone have an idea…
Thanks,
