FAIL: Python wrapper cron entry is not present
I’m getting the following errors when validating
[FAIL] Poller is not running. No poller has run within the last 300 seconds.
[FAIL] Python wrapper cron entry is not present
LibreNMS  | 24.8.0-61-gf1e7a218f (2024-09-09T09:48:07-07:00)
DB Schema | 2024_08_27_182000_ports_statistics_table_rev_length (299)
PHP       | 8.1.2-1ubuntu2.18
Python    | 3.10.12
Database  | MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1
SNMP      | 5.9.1
[OK]    Composer Version: 2.7.9
**[FAIL]  Python wrapper cron entry is not present**
[OK]    Redis is unavailable
[OK]    rrd_dir is writable
librenms@librenms:~$ ./discovery.php -h HOSTNAME -d | ./pbin.sh
Paste endpoint: https://p.libren.ms/api/create
title:
private: 1
expire: 0
https://p.libren.ms/view/f12c0240
librenms@librenms:~$ ./poller.php -h HOSTNAME -r -f -d | ./pbin.sh
title:
private: 1
expire: 0
https://p.libren.ms/view/65637e70
my /etc/cron.d/librenms file
33   */6  * * *   librenms    /opt/librenms/cronic /opt/librenms/discovery-wrapper.py 1
*/5  *    * * *   librenms    /opt/librenms/discovery.php -h new >> /dev/null 2>&1
*/5  *    * * *   librenms    /opt/librenms/cronic /opt/librenms/poller-wrapper.py 16
*    *    * * *   librenms    /opt/librenms/alerts.php >> /dev/null 2>&1
*/5  *    * * *   librenms    /opt/librenms/poll-billing.php >> /dev/null 2>&1
01   *    * * *   librenms    /opt/librenms/billing-calculate.php >> /dev/null 2>&1
*/5  *    * * *   librenms    /opt/librenms/check-services.php >> /dev/null 2>&1
# Daily maintenance script. DO NOT DISABLE!
# If you want to modify updates:
#  Switch to monthly stable release: https://docs.librenms.org/General/Releases/
#  Disable updates: https://docs.librenms.org/General/Updating/
19   0    * * *   librenms    /opt/librenms/daily.sh >> /dev/null 2>&1
As we can see here the librenms-scheduler is running every minute.
librenms@librenms:~$ service librenms-scheduler status
* librenms-scheduler.service - LibreNMS Scheduler
     Loaded: loaded (/etc/systemd/system/librenms-scheduler.service; static)
     Active: inactive (dead) since Mon 2024-09-09 20:22:01 PDT; 19s ago
TriggeredBy: * librenms-scheduler.timer
    Process: 19076 ExecStart=/usr/bin/env php artisan schedule:run --no-ansi --no-interaction (code=exited, status=0/>
   Main PID: 19076 (code=exited, status=0/SUCCESS)
I’m at a lost at why it’s not seeing the Python wrapper cron entries.
poller-wrapper.py is busted …
might pay to migrate to systemd and librenms-service.py rather than cron …
