After moving to dedicated database server with memcached enabled, i am getting the “Scheduler is not running” error. Everything else seems to be working, polling etc. Even if I check the scheduler service status on my server, I can see it running and doing it’s schedules. The suggested fix has no effect.
Validate.php:
| Component |
Version |
| LibreNMS |
25.1.0-119-g91840af2b (2025-02-17T18:35:47+02:00) |
| DB Schema |
2025_01_30_000121_add_ifindex_index_to_ports_table (315) |
| PHP |
8.3.13 |
| Python |
3.9.21 |
| Database |
MySQL 8.0.36 |
| RRDTool |
1.7.2 |
| SNMP |
5.9.1 |
[OK] Composer Version: 2.8.4
[FAIL] Scheduler is not running
sudo cp /opt/librenms/dist/librenms-scheduler.service /opt/librenms/dist/librenms-scheduler.timer /etc/systemd/system/
sudo systemctl enable librenms-scheduler.timer
sudo systemctl start librenms-scheduler.timer
daily.sh:
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Some update, everything indeed seems to be working except that fail in validate.php in UI or CLI.
systemctl status librenms-scheduler.timer
? librenms-scheduler.timer - LibreNMS Scheduler
Loaded: loaded (/etc/systemd/system/librenms-scheduler.timer; enabled; preset: disabled)
Active: active (waiting) since Fri 2025-02-21 11:55:36 EET; 3h 41min ago
Until: Fri 2025-02-21 11:55:36 EET; 3h 41min ago
Trigger: Fri 2025-02-21 15:38:00 EET; 47s left
Triggers: ? librenms-scheduler.service Started LibreNMS Scheduler.
systemctl status librenms-scheduler.service
? librenms-scheduler.service - LibreNMS Scheduler
Loaded: loaded (/etc/systemd/system/librenms-scheduler.service; static)
Active: inactive (dead) since Fri 2025-02-21 15:38:00 EET; 34s ago
TriggeredBy: ? librenms-scheduler.timer
Process: 275372 ExecStart=/usr/bin/env php artisan schedule:run --no-ansi --no-interaction (code=exited, status=0/SUCCESS)
Main PID: 275372 (code=exited, status=0/SUCCESS)
CPU: 500ms Starting LibreNMS Scheduler…
librenms-scheduler.service: Deactivated successfully.
Finished LibreNMS Scheduler.
I installed a poller and the issue followed there. A fresh install without errors including this part:
There are no errors in any logs and everything is running well and smoothly.
In another topic someone mentioned getting this error after running
./scripts/github-remove -d
I am still wondering is this something i should be worried about? Everything is running well and smooth, no problems anywhere what so ever and the latest major update went fine.
| Component |
Version |
| LibreNMS |
25.3.0-42-gf4e45f488 (2025-03-25T03:20:22+02:00) |
| DB Schema |
2025_03_22_134124_fix_ipv6_addresses_id_type (323) |
| PHP |
8.3.13 |
| Python |
3.9.21 |
| Database |
MySQL 8.0.41 |
| RRDTool |
1.7.2 |
| SNMP |
5.9.1 |
[OK] Composer Version: 2.8.6
Yes, you need to enable the librenms-scheduler.timer. It does not do much at this time, but it will do more over time. (one thing it does is update the mac oui database)
Thanks for the info. The problem is that when i execute the suggested fix, nothing seems to happen. Even according to logs the timer runs at set times.
Active: active (waiting) since Mon 2025-03-24 04:34:21; 2 days ago
Until: Mon 2025-03-24 04:34:21; 2 days ago
Trigger: Wed 2025-03-26 09:14:00; 48s left
Mar 24 04:34:21 systemd[1]: Started LibreNMS Scheduler.
I added this to the cron file but no effect:
- librenms cd /opt/librenms/ && php artisan schedule:run >> /dev/null 2>&1
Logs from scheduler itself:
2025-03-26 14:30:02 Running [Callback] … 1ms DONE
INFO No scheduled commands are ready to run.
2025-03-26 14:35:02 Running [Callback] … 1ms DONE
2025-03-26 14:40:01 Running [Callback] … 1ms DONE
Seems correct , maybe you have an issue with your cache driver.
Thank you! I went to look at that and… oh for crying out loud.
In addition to CACHE_DRIVER in .env I had to add the memcached host and port into the .env
" Using Memcached
Preferably you should set the memcached server settings via the web UI. Under Settings > Global Settings > Distributed poller, you fill out the memcached host and port, and then in your .env file you will need to add:
CACHE_DRIVER=memcached
MEMCACHED_HOST='myhost' <-----------------ADDED
MEMCACHED_PORT=memcachedport <--------------- ADDED
Even though they were added in the web UI.
Anyway thanks, seems to work now.
