I have a problem with installing LibreNMS via docker.
I followed the steps here Docker - LibreNMS Docs and I configured firewalls before the server to access it via TCP 8000.
But I am still rejected by the server, and I don’t know why.
I can see the requests coming via tcpdump and all immediately being rejected by the server.
Here is the validation.php from the docker
librenms:/opt/librenms$ ./validate.php
| LibreNMS | 24.9.0 (2024-10-15T21:15:45+02:00) |
| DB Schema | 2024_08_27_182000_ports_statistics_table_rev_length (300) |
| PHP | 8.3.8 |
| Python | 3.11.10 |
| Database | MariaDB 10.11.9-MariaDB-ubu2204 |
| RRDTool | 1.8.0 |
| SNMP | 5.9.4 |
[WARN] You have no devices.
Consider adding a device such as localhost: /addhost
[OK] Redis is functional
[INFO] fping FAILURES can be ignored if running LibreNMS in a jail without ::1. You may want to test it manually: fping ::1
[FAIL] /usr/sbin/fping6 could not be executed. /usr/sbin/fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exclusions may be required.
(/usr/sbin/fping: can’t create socket (must run as root?))
[FAIL] /usr/sbin/fping6 should have CAP_NET_RAW!
setcap cap_net_raw+ep /usr/sbin/fping6
