False alarms and confused voltage health limits
Yesterday after 1 am my LibreNMS started sending alarms that all power supply voltages were out of parameters, on all servers in my network.
After reviewing the voltages (the information is downloaded from IPMI) it turned out that the limits were messed up.
On one of the servers I deleted the limits, ran a new scan, but the limits did not appear.
How can I fix this?
~$ ./validate.php
LibreNMS  | 25.9.0-dev.9+a4b49cb6b (2025-08-20T20:22:29+03:00)
DB Schema | 2025_07_10_201918_update_vlans_table (353)
PHP       | 8.3.24
Python    | 3.11.2
Database  | MariaDB 10.11.13-MariaDB-0+deb12u1
SNMP      | 5.9.3
[OK]    Composer Version: 2.8.10
[OK]    Redis is functional
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
When I try to execute the command with
./discovery.php -h HOSTNAME -d | curl --data-binary @- https://paste.rs/
I get the following error:
./discovery.php -h nasa -d | curl --data-binary @- https://paste.rs/
<html>
<head><title>500 Internal Server Error</title></head>
<body bgcolor="white">
<center><h1>500 Internal Server Error</h1></center>
<hr><center>nginx</center>
</body>
</html>
./poller.php -h HOSTNAME -r -f -d | curl --data-binary @- https://paste.rs/
If you need to post any text longer than a few lines, please use a “pastebin” service, we recommend using https://paste.rs/ or https://paste.sh/
