I enabled “fast ping check” according to the documentation by doing the following steps:
Adding $config[‘ping_rrd_step’] = 60; to the config-file
Running ./scripts/rrdstep.php -h all to fix the rrd steps
Adding the required cron-job
- librenms /opt/librenms/ping.php >> /dev/null 2>&1
After this I checked the ping-perf.rrd files with rrdinfo and checked that the correct steps were changed
After this the poller “ping response” graphs were unreliable…
Running ping.php manually (with -v) I noticed that it reported this output:
Attempting to record data for 10.110.7.26… Success
Device 10.110.7.26 changed status to , running alerts
Rule #2 (Devices up/down): Status: NOCHG
Rule #3 (Port errors on important switchport): Status: NOCHG
Rule #4 (Palo Alto Networks passive firewall changed to active): Status: NOCHG
Rule #5 (Processor usage over 75%): Status: NOCHG
Rule #6 (Broadcast/Multicast Storm): Status: NOCHG
RRDtool Output: Attempting to record data for 10.110.7.10… Success
Device 10.110.7.10 changed status to , running alerts
RRDtool Output: OK u:0.00 s:0.01 r:0.00
Attempting to record data for 10.110.5.10… Success
Device 10.110.5.10 changed status to , running alerts
RRDtool Output: OK u:0.00 s:0.01 r:0.04
Attempting to record data for 10.110.7.37… Deferred
Attempting to record data for 10.110.5.18… Deferred
Attempting to record data for 10.110.5.17… Deferred
if i run ping.php -d -v it will show a report at the end that says:
Leftover devices, this shouldn’t happen: 10.110.7.37, 10.110.5.17, 10.110.5.16, 10.110.5.15, 10.110.5.14, 10.110.5.13, 10.110.5.31, 10.110.5.22,
It seems like it manages to record data for the first 2-4 devices when I run it… but the rest are Deferred…
Any idea what may be causing this ?
Component | Version |
LibreNMS | 1.63-82-g1dd0d46ed |
DB Schema | 2020_04_19_010532_eventlog_sensor_reference_cleanup (164) |
PHP | 7.2.24-0ubuntu0.18.04.4 |
Python | 3.6.9 |
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.6
