I’ve just implemented fast ping monitoring on our LibreNMS cluster.
Ping.php runs every 30 seconds (at 0 & 30 seconds), and alerts.php runs every 30 seconds (at 15 & 45 seconds). As we have distributed polling each poller is using its own group (cron job line has - ping.php -g X)
When ICMP reports a device down, LibreNMS doesn’t send the down alert until poller.php is run (which is every 5 minutes). Instead of getting ICMP Down alerts within 30 seconds it’s still taking at most 5-6 minutes for the alert to come through. That said, when ICMP starts responding again, the ‘restored’ alert comes through within 30 seconds (without poller.php being run). I’m not sure what I’m missing for ping.php to not add the alert for alerts.php to send.
I followed Cron job for fast-ping (ping.php) don't work correct however this didn’t work for me in getting the down alerts to send.
For the alert rule, I’ve tried “devices.status_reason equal ICMP” and “macros.device_down equal yes”. And also without the Macros with “devices.status equal down”. But no luck.
$ ./validate.php
Component Version LibreNMS 1.56-7-g51e5521d9 DB Schema 2019_08_28_105051_fix-template-linefeeds (143) PHP 7.2.19-0ubuntu0.18.04.2 MySQL 10.1.41-MariaDB-0ubuntu0.18.04.1 RRDTool 1.7.0 SNMP NET-SNMP 5.7.3 ==================================== [OK] Composer Version: 1.9.0
Regards,
Derova
