The current Procedure URL field only seems to allow up to 80 characters. This is all well and good for those who host simple web servers with documentation on board, but what if you’re running out of SharePoint or some other document management system that has much larger URLs?
Can we get the 80-character limit lifted or changed to accommodate up to 500 characters or perhaps1000 and then add an additional field for a “short name” for the URL?
The Procedure URL field can be extremely handy but limiting it to 80 characters can limit the ability to use this function.
Thanks!
