Feature Request: Scheduled maintenance for ports
Common occurrence for us:
Transit provider sends out maintenance notification for a given link, and we need to reroute traffic from it & suppress alerting for the duration of maintenance.
Few things I could think of to achieve this:
  • Set the whole device under scheduled maintenance.
  • Build individual alerts for each such link, to be toggled on and off, and remove link tracking from other port monitoring alert rules
  • Wait for alert to fire and then acknowledge it.
  • Edit device settings → port settings → toggle Ignore Alert Tag for affected link
None of these are particularly suitable.
We explicitly don’t want to set the whole device under maintenance, as that shuts off alerting for other, valid things.
There would be significant configuration overhead for creating a dedicated alert for each of these links, especially since we have quite a bit of these.
Waiting for alert and then acknowledging it is just dumb.
So the toggle Ignore Alert Tag is I guess the least bad out of these.
Currently Scheduled Maintenance is restricted to be applicable only for:
Locations, Device Groups, Devices
What I would instead want is an actual Scheduled Maintenance for a specific port. Especially since there one could set a timeframe when the alert needs ignoring, so no need to manually remember to set the alerting back on.
So I would request to add Scheduled Maintenance to also apply for:
  • Port Groups
  • Ports
Nice to have would also be:
  • Alert Rule
So that any alert rule could be turned off for a given timeframe.
In my head these sound simple enough, but I have a suspicion it might not be the case.
This would be immensely useful in any service provider environment. Currently setting interface “maintenance” would involve an external system to toggle the ignore alert tag off and on per interface via api. While this can work, it would be much more useful to be able to simply set a maintenance window for interfaces (manually or via api).
we tag our interfaces during maintenances/planned outages etc and then have an alert rule that disregards those ports
ports.ifAdminStatus = "up" AND ports.ifOperStatus != "up" AND ports.ifAlias REGEXP ".*((^|:)T=B).*" AND ports.ifAlias NOT REGEXP ".*DRAIN.*"
The ability to have a log of scheduled maintenance is really important for audits. So having the flexibility to schedule maintenance and either tie the maintenance to specific alerts, OR to specific peers or ports would be very helpful.
As mentioned above, when people have carrier maintenance the entire device should still be monitored except for the (1) port and/or (1) peer.
Since alerts already have the ability to be enabled / disabled. I would imagine tying that into the scheduling process could be easy. Then administrators can have multiple alerts and tie those alerts to the maintenance activity.
This would be extremely useful…
How can this be made into an official feature request?
It is “official”, but keep in mind LibreNMS is a community project. Things only get done when community members contribute them.
This is very useful for alerts about port saturation where we have to wait months for it to be resolved.
