Hi All,
Could any one assist me with the API call for oxidized please?
If I curl from Oxidized server to librenms - it is sucessful
curl -H “xxxxx” http://10.10.10.11/api/v0/oxidized
"hostname": "b",
"os": "generic",
"ip": "1.1.1.12"
"hostname": "A",
"os": "generic",
"ip": "1.1.1.1"
If I run oxidized I am not loading any nodes
]root-aaa@xxxd:/opt/oxidized/.config# oxidized
I, [2020-09-09T20:15:48.021161 #2219955 ] INFO – : Oxidized starting, running as pid 2219955
I, [2020-09-09T20:15:48.022029 #2219955 ] INFO – : lib/oxidized/nodes.rb: Loading nodes
I, [2020-09-09T20:15:48.022150 #2219955 ] INFO – : lib/oxidized/nodes.rb: Loaded 0 nodes
F, [2020-09-09T20:15:48.022192 #2219955 ] FATAL – : Oxidized crashed, crashfile written in /opt/oxidized/crash
oxidized config is
log: /home/oxidized/.config/oxidized/log
username: ommited
resolve_dns: false
password: “ommited”
model: junos
resolve_dns: true
interval: 3600
use_syslog: true
debug: true
threads: 30
timeout: 20
retries: 3
rest: 0.0.0.0:8888
next_adds_job: true
vars: {}
groups: {}
models: {}
pid: “/opt/oxidized/.config/pid”
crash:
directory: “/opt/oxidized/.config/crash”
hostnames: true
stats:
history_size: 10
input:
default: ssh, telnet
debug: true
ssh:
secure: false
ftp:
passive: true
utf8_encoded: false
output:
default: git
git:
user: oxidized
email: [email protected]
repo: “/opt/oxidized/.config/configs/devices.git”
source:
default: http
debug: false
http:
url: http://10.10.10.11/api/v0/oxidized
delimiter: !ruby/regexp /
map:
model: os
headers:
X-Auth-Token: “xxxx”
model_map:
juniper: junos
cisco: ios
hp: procurve
asa: asa
generic: ios
is your oxidized instance on the same machine as your librenms instance?
Elias
10 September 2020 18:21
3
What does the crashfile contain? Since the process is crashing can’t really call it an issue with the api communication.
This is what I get when trying to start Oxidized
2020-09-09 21:49:31 UTC
source returns no usable nodes [Oxidized::Core::NoNodesFound]
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/core.rb:15:in initialize' /var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/core.rb:4:in new’
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/core.rb:4:in new' /var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/cli.rb:13:in run’
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/bin/oxidized:8:in <top (required)>' /usr/local/bin/oxidized:23:in load’
/usr/local/bin/oxidized:23:in `’
Elias
11 September 2020 12:25
5
Hmmm ok so it crashes if no usable nodes are found, funky behaviour…
This is my working config, maybe try to change some parameters:
username: user
password: password
resolve_dns: true
interval: 3600
use_syslog: true
debug: false
threads: 4
timeout: 500
retries: 3
rest: 0.0.0.0:8888
next_adds_job: false
vars: {}
groups: {}
models: {}
pid: “/home/oxidized/.config/oxidized/pid”
crash:
directory: “/home/oxidized/.config/oxidized/crashes”
hostnames: true
stats:
history_size: 10
input:
default: ssh
debug: false
ssh:
secure: false
source:
default: http
debug: false
http:
url: http://librenms/api/v0/oxidized
map:
model: os
group: group
headers:
X-Auth-Token: numbersandletters
output:
default: git
git:
user: git
repo: “/home/oxidized/oxidized_repo/”
hooks:
push_to_remote:
type: githubrepo
events: [post_store]
remote_repo: ssh://git@gittything/oxidized.git
publickey: /home/oxidized/.ssh/id_rsa.pub
privatekey: /home/oxidized/.ssh/id_rsa
model_map:
arista_eos: eos
juniper: junos
fortigate: fortios
vyos: vyatta
models:
eos:
vars:
auth_methods: [ “keyboard-interactive” ]
