Few of my devices (cisco 2960) mostly are discovered as generic devices…
ANy help will be appreciated.
-bash-4.2$ ./validate.php
| LibreNMS | 21.5.1-31-g2a66d68 |
| DB Schema | 2021_06_11_084830_slas_add_rtt_field (210) |
| PHP | 7.3.28 |
| Python | 3.6.8 |
| MySQL | 10.5.10-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 2.1.3
[WARN] Global lnms shortcut not installed. lnms command must be run with full path
sudo ln -s /opt/librenms/lnms /usr/bin/lnms
[WARN] Bash completion not installed. lnms command tab completion unavailable.
sudo cp /opt/librenms/misc/lnms-completion.bash /etc/bash_completion.d/
Modified Files:
bootstrap/cache/.gitignore
config.php.default
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
-bash-4.2$ ./discovery.php -h s1_snif634 -d
LibreNMS Discovery
SQL[select migration from migrations order by id desc limit 1 0.36ms]
SQL[select count(*) as aggregate from migrations limit 1 0.32ms]
SQL[SELECT version() 0.21ms]
Version info:
Commit SHA: 2a66d68c18a716de4f8705e19cc54df7a3778b6b
Commit Date: 1623449122
DB Schema: 2021_06_11_084830_slas_add_rtt_field (210)
PHP: 7.3.28
MySQL: 10.5.10-MariaDB
RRDTool: 1.4.8
SNMP: NET-SNMP 5.7.2
Updating os_def.cache
SQL[SELECT * FROM devices WHERE disabled = 0 AND snmp_disable = 0 AND hostname LIKE ‘s1_snif634’ ORDER BY device_id DESC 0.68ms]
SQL[select * from devices where device_id = ? limit 1 [34] 0.64ms]
SQL[select * from devices_attribs where devices_attribs.device_id = ? and devices_attribs.device_id is not null [34] 0.29ms]
s1_snif634 34 generic SQL[select hostname, overwrite_ip from devices where hostname = ? limit 1 [“s1_snif634”] 0.27ms]
[FPING] ‘/usr/sbin/fping’ ‘-e’ ‘-q’ ‘-c’ ‘3’ ‘-p’ ‘500’ ‘-t’ ‘500’ ‘s1_snif634’
response: {“xmt”:3,“rcv”:3,“loss”:0,“min”:18.100000000000001,“max”:18.800000000000001,“avg”:18.5,“dup”:0,“exitcode”:0}
SQL[select device_groups.*, device_group_device.device_id as pivot_device_id, device_group_device.device_group_id as pivot_device_group_id from device_groups inner join device_group_device on device_groups.id = device_group_device.device_group_id where device_group_device.device_id = ? [34] 0.51ms]
SQL[select exists(select * from alert_schedule where (start <= ? and end >= ? and (recurring = ? or (recurring = ? and ((time(start) < time(end) and time(start) <= ? and time(end) > ?) or (time(start) > time(end) and (time(end) <= ? or time(start) > ?))) and (recurring_day like ? or recurring_day is null)))) and (exists (select * from devices inner join alert_schedulables on devices.device_id = alert_schedulables.alert_schedulable_id where alert_schedule.schedule_id = alert_schedulables.schedule_id and alert_schedulables.alert_schedulable_type = ? and alert_schedulables.alert_schedulable_id = ?))) as exists [“2021-06-12T19:29:13.321297Z”,“2021-06-12T19:29:13.321297Z”,0,1,“19:29:13”,“19:29:13”,“19:29:13”,“19:29:13”,“%”,“device”,34] 0.63ms]
SQL[INSERT IGNORE INTO device_perf (xmt,rcv,loss,min,max,avg,device_id,timestamp,debug) VALUES (:xmt,:rcv,:loss,:min,:max,:avg,:device_id,NOW(),:debug) {“xmt”:3,“rcv”:3,“loss”:0,“min”:18.100000000000001,“max”:18.800000000000001,“avg”:18.5,“device_id”:34,“debug”:“”} 0.95ms]
SQL[UPDATE devices set last_ping=?,last_ping_timetaken=? WHERE device_id=? [“2021-06-12 22:29:13”,18.5,34] 0.96ms]
SNMP Check response code: 0
Modules status: Global+
OS
Device
Load disco module core
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQn’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘sysName.0’ ‘sysObjectID.0’ ‘sysDescr.0’]
...0 = No Such Object available on this agent at this OID
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/arris’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.1166.1.621.14.2.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.8072.1.3.2.3.1.2.6.100.105.115.116.114.111’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/endrun’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.13827.12.1.16.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/eltek’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.12148.10.2.6.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/hikvision’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.39165.1.1.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/orvaldi’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.21111.1.1.1.6.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘1.3.6.1.4.1.4515.1.3.6.1.1.1.2.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/wisi’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.7465.20.2.9.1.2.1.3.1.2’]
Attempting to initialize OS: generic
OS initialized: LibreNMS\OS\Generic
OS: Generic Device (generic)
Runtime for discovery module ‘core’: 0.3310 seconds with 136888 bytes
SNMP: [10/0.37s] MySQL: [3/0.00s] RRD: [0/0.00s]
Unload disco module core
OS
Device
Load disco module os
Yaml location data:
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysLocation.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Ovq’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘sysContact.0’]
Yaml OS data:
Hardware:
OS Version:
OS Features:
Serial:
Runtime for discovery module ‘os’: 0.0700 seconds with 96248 bytes
SNMP: [4/0.07s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module os
OS
Device
Load disco module ports
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ifDescr’]
ifDescr = No more variables left in this MIB View (It is past the end of the MIB tree)
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ifName’]
ifName = No more variables left in this MIB View (It is past the end of the MIB tree)
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ifAlias’]
ifAlias = No more variables left in this MIB View (It is past the end of the MIB tree)
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ifType’]
ifType = No more variables left in this MIB View (It is past the end of the MIB tree)
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ifOperStatus’]
ifOperStatus = No more variables left in this MIB View (It is past the end of the MIB tree)
array (
SQL[SELECT * FROM ports WHERE device_id = ? ORDER BY port_id [34] 0.71ms]
Runtime for discovery module ‘ports’: 0.2150 seconds with 5592 bytes
SNMP: [5/0.21s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ports
OS
Device
Load disco module ports-stack
SQL[SELECT * FROM ports_stack WHERE device_id = ‘34’ 0.31ms]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ifStackStatus’]
ifStackStatus = No more variables left in this MIB View (It is past the end of the MIB tree)
Runtime for discovery module ‘ports-stack’: 0.0370 seconds with 1904 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ports-stack
OS
Device
Load disco module entity-physical
Caching OIDs: entPhysicalEntrySNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘ENTITY-MIB:CISCO-ENTITY-VENDORTYPE-OID-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘entPhysicalEntry’]
entPhysicalEntry = No more variables left in this MIB View (It is past the end of the MIB tree)
MIB search path: /opt/librenms/mibs
Cannot find module (CISCO-ENTITY-VENDORTYPE-OID-MIB): At line 0 in (none)
SQL[SELECT * FROM entPhysical WHERE device_id = ? [34] 0.56ms]
Runtime for discovery module ‘entity-physical’: 0.0370 seconds with 8000 bytes
SNMP: [1/0.04s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module entity-physical
OS
Device
Load disco module entity-state
SQL[SELECT entPhysical_id, entPhysicalIndex FROM entPhysical WHERE device_id=? [34] 0.29ms]
Runtime for discovery module ‘entity-state’: 0.0000 seconds with 2104 bytes
Unload disco module entity-state
OS
Device
Load disco module isis
SQL[select * from component where device_id = ? and type = ? [34,“ISIS”] 0.38ms]
communityStringIndexing
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘ISIS-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ISIS-MIB::isisCirc’]
isisCirc = No more variables left in this MIB View (It is past the end of the MIB tree)
Runtime for discovery module ‘isis’: 0.0330 seconds with 93944 bytes
SNMP: [0/0.00s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module isis
OS
Device
Load disco module processors
No YAML Discovery data.
Host Resources: SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘HOST-RESOURCES-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘hrProcessorLoad’]
hrProcessorLoad = No more variables left in this MIB View (It is past the end of the MIB tree)
UCD Resources: SQL[select * from vrf_lite_cisco where vrf_lite_cisco.device_id = ? and vrf_lite_cisco.device_id is not null [34] 0.46ms]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Ovq’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.2021.11.11.0’]
SQL[SELECT * FROM processors WHERE device_id=? [34] 0.42ms]
SQL[DELETE T FROM processors T LEFT JOIN devices ON devices.device_id = T.device_id WHERE devices.device_id IS NULL 0.43ms]
Runtime for discovery module ‘processors’: 0.0770 seconds with 90384 bytes
SNMP: [2/0.07s] MySQL: [2/0.00s] RRD: [0/0.00s]
Unload disco module processors
OS
Device
Load disco module mempools
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘hrStorageTable’]
hrStorageTable = No more variables left in this MIB View (It is past the end of the MIB tree)
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUv’ ‘-m’ ‘HOST-RESOURCES-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘hrMemorySize.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘UCD-SNMP-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘memTotalSwap.0’ ‘memAvailSwap.0’ ‘memTotalReal.0’ ‘memAvailReal.0’ ‘memBuffer.0’ ‘memCached.0’ ‘memSysAvail.0’]
memTotalSwap.0 = No Such Object available on this agent at this OID
memAvailSwap.0 = No Such Object available on this agent at this OID
memTotalReal.0 = No Such Object available on this agent at this OID
memAvailReal.0 = No Such Object available on this agent at this OID
memBuffer.0 = No Such Object available on this agent at this OID
memCached.0 = No Such Object available on this agent at this OID
memSysAvail.0 = No Such Object available on this agent at this OID
SQL[select * from mempools where mempools.device_id = ? and mempools.device_id is not null [34] 0.55ms]
Runtime for discovery module ‘mempools’: 0.1020 seconds with 89280 bytes
SNMP: [2/0.06s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module mempools
OS
Device
Load disco module cisco-vrf-lite
SQL[SELECT * FROM vrf_lite_cisco WHERE device_id = ? [34] 0.41ms]
Runtime for discovery module ‘cisco-vrf-lite’: 0.0000 seconds with 2648 bytes
Unload disco module cisco-vrf-lite
OS
Device
Load disco module cisco-mac-accounting
Runtime for discovery module ‘cisco-mac-accounting’: 0.0000 seconds with 928 bytes
Unload disco module cisco-mac-accounting
OS
Device
Load disco module cisco-pw
Runtime for discovery module ‘cisco-pw’: 0.0000 seconds with 1480 bytes
Unload disco module cisco-pw
OS
Device
Load disco module vrf
SQL[SELECT * FROM ports WHERE device_id = ‘34’ 0.46ms]
SQL[SELECT * FROM vrfs WHERE device_id = ‘34’ 0.32ms]
Runtime for discovery module ‘vrf’: 0.0010 seconds with 4520 bytes
SNMP: [0/0.00s] MySQL: [2/0.00s] RRD: [0/0.00s]
Unload disco module vrf
OS
Device
Load disco module cisco-cef
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘CISCO-CEF-MIB::cefSwitchingPath’]
Exitcode: 1
Cannot find module (CISCO-CEF-MIB): At line 0 in (none)
CISCO-CEF-MIB::cefSwitchingPath: Unknown Object Identifier
array (
Caching OIDs: entPhysicalDescrSNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘ENTITY-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘entPhysicalDescr’]
entPhysicalDescr = No more variables left in this MIB View (It is past the end of the MIB tree)
entPhysicalNameSNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘ENTITY-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘entPhysicalName’]
entPhysicalName = No more variables left in this MIB View (It is past the end of the MIB tree)
entPhysicalModelNameSNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘ENTITY-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘entPhysicalModelName’]
entPhysicalModelName = No more variables left in this MIB View (It is past the end of the MIB tree)
Runtime for discovery module ‘cisco-cef’: 0.1470 seconds with 3256 bytes
SNMP: [3/0.13s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module cisco-cef
OS
Device
Load disco module slas
Runtime for discovery module ‘slas’: 0.0000 seconds with 4752 bytes
Unload disco module slas
OS
Device
Load disco module cisco-cbqos
Runtime for discovery module ‘cisco-cbqos’: 0.0000 seconds with 2304 bytes
Unload disco module cisco-cbqos
OS
Device
Load disco module cisco-otv
Runtime for discovery module ‘cisco-otv’: 0.0000 seconds with 4224 bytes
Unload disco module cisco-otv
OS
Device
Load disco module cisco-qfp
Runtime for discovery module ‘cisco-qfp’: 0.0000 seconds with 1152 bytes
Unload disco module cisco-qfp
OS
Device
Load disco module ipv4-addresses
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Osq’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ipAdEntIfIndex’]
ipAdEntIfIndex No more variables left in this MIB View (It is past the end of the MIB tree)
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ipAdEntNetMask.’]
SQL[SELECT ipv4_addresses.*, ports.device_id, ports.ifIndex FROM ipv4_addresses LEFT JOIN ports ON ipv4_addresses.port_id = ports.port_id WHERE ports.device_id = ? OR ports.device_id IS NULL [34] 4.16ms]
Runtime for discovery module ‘ipv4-addresses’: 0.0680 seconds with 40792 bytes
SNMP: [2/0.06s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ipv4-addresses
OS
Device
Load disco module ipv6-addresses
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Osq’ ‘-Ln’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ipAddressIfIndex.ipv6’]
ipAddressIfIndex.ipv6 No more variables left in this MIB View (It is past the end of the MIB tree)
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OsqnU’ ‘-Ln’ ‘-m’ ‘IPV6-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘ipv6AddrPfxLength’]
...8.1.2 No more variables left in this MIB View (It is past the end of the MIB tree)
SQL[SELECT ipv6_addresses.*, ports.device_id, ports.ifIndex FROM ipv6_addresses LEFT JOIN ports ON ipv6_addresses.port_id = ports.port_id WHERE ports.device_id = ? OR ports.device_id IS NULL [34] 0.54ms]
Runtime for discovery module ‘ipv6-addresses’: 0.0850 seconds with 3544 bytes
SNMP: [2/0.08s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ipv6-addresses
OS
Device
Load disco module route
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Osqn’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘IP-FORWARD-MIB::inetCidrRouteNumber.0’]
...6.0 No Such Object available on this agent at this OID
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IP-FORWARD-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘inetCidrRouteNumber.0’ ‘ipCidrRouteNumber.0’]
inetCidrRouteNumber.0 = No Such Object available on this agent at this OID
ipCidrRouteNumber.0 = No Such Object available on this agent at this OID
SQL[select now() as now 0.34ms]
SQL[select * from route where device_id = ? [34] 2.25ms]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘RFC1213-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.2.1.4.21’]
ipRouteTable = No more variables left in this MIB View (It is past the end of the MIB tree)
Routing table:
array (
RFC1213 communityStringIndexing
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘MPLS-L3VPN-STD-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘mplsL3VpnVrfPerfCurrNumRoutes’]
mplsL3VpnVrfPerfCurrNumRoutes = No more variables left in this MIB View (It is past the end of the MIB tree)
mplsL3VpnVrfRteTable communityStringIndexing
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘MPLS-L3VPN-STD-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘mplsL3VpnVrfRteTable’]
mplsL3VpnVrfRteTable = No more variables left in this MIB View (It is past the end of the MIB tree)
Processing:
Runtime for discovery module ‘route’: 0.2010 seconds with 12792 bytes
SNMP: [2/0.08s] MySQL: [2/0.00s] RRD: [0/0.00s]
Unload disco module route
OS
Device
Load disco module sensors
ENTITY-SENSOR: Caching OIDs: entPhysicalDescr
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“voltage”,34,“ipmi”] 0.75ms]
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“temperature”,34,“ipmi”] 0.53ms]
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“fanspeed”,34,“ipmi”] 0.48ms]
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“power”,34,“ipmi”] 0.47ms]
Airflow: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“airflow”,34,“snmp”] 0.49ms]
Current: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“current”,34,“snmp”] 0.47ms]
Charge: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“charge”,34,“snmp”] 0.49ms]
Dbm: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“dbm”,34,“snmp”] 0.46ms]
Fanspeed: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“fanspeed”,34,“snmp”] 0.5ms]
Frequency: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“frequency”,34,“snmp”] 0.5ms]
Humidity: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“humidity”,34,“snmp”] 0.48ms]
Load: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“load”,34,“snmp”] 0.48ms]
Loss: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“loss”,34,“snmp”] 0.48ms]
Power: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“power”,34,“snmp”] 0.45ms]
Power_consumed: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“power_consumed”,34,“snmp”] 0.48ms]
Power_factor: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“power_factor”,34,“snmp”] 0.46ms]
Runtime: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“runtime”,34,“snmp”] 0.5ms]
Signal: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“signal”,34,“snmp”] 0.48ms]
State: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“state”,34,“snmp”] 0.45ms]
Count: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“count”,34,“snmp”] 0.53ms]
Temperature: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“temperature”,34,“snmp”] 0.46ms]
Tv_signal: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“tv_signal”,34,“snmp”] 0.46ms]
Voltage: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“voltage”,34,“snmp”] 0.46ms]
Snr: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“snr”,34,“snmp”] 0.48ms]
Pressure: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“pressure”,34,“snmp”] 0.46ms]
Cooling: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“cooling”,34,“snmp”] 0.52ms]
Delay: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“delay”,34,“snmp”] 0.46ms]
Quality_factor: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“quality_factor”,34,“snmp”] 0.46ms]
Chromatic_dispersion: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“chromatic_dispersion”,34,“snmp”] 0.48ms]
Ber: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“ber”,34,“snmp”] 0.46ms]
Eer: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“eer”,34,“snmp”] 0.48ms]
Waterflow: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“waterflow”,34,“snmp”] 0.48ms]
Percent: array (
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=? AND S.device_id = D.device_id AND D.device_id = ? AND S.poller_type = ? [“percent”,34,“snmp”] 0.48ms]
Runtime for discovery module ‘sensors’: 0.0220 seconds with 63992 bytes
SNMP: [0/0.00s] MySQL: [33/0.02s] RRD: [0/0.00s]
Unload disco module sensors
OS
Device
Load disco module storage
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IBM-AIX-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘aixFsTableEntry’]
Exitcode: 1
Cannot find module (IBM-AIX-MIB): At line 0 in (none)
aixFsTableEntry: Unknown Object Identifier (Sub-id not found: (top) → aixFsTableEntry)
aix_filesystem : SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘DATA-DOMAIN-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/datadomain’ ‘udp:HOSTNAME:161’ ‘fileSystemSpaceTable’]
fileSystemSpaceTable = No more variables left in this MIB View (It is past the end of the MIB tree)
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘FREENAS-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘datasetTable’]
Exitcode: 1
Cannot find module (FREENAS-MIB): At line 0 in (none)
datasetTable: Unknown Object Identifier (Sub-id not found: (top) → datasetTable)
SQL[SELECT storage_descr FROM storage WHERE device_id = ‘34’ AND storage_type != ‘dataset’ 0.51ms]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘FREENAS-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘zpoolTable’]
Exitcode: 1
zpoolTable: Unknown Object Identifier (Sub-id not found: (top) → zpoolTable)
SQL[SELECT storage_descr FROM storage WHERE device_id = ‘34’ AND storage_type != ‘zpool’ 0.5ms]
hrStorage : SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘UCD-SNMP-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘udp:HOSTNAME:161’ ‘dskTable’]
dskTable = No more variables left in this MIB View (It is past the end of the MIB tree)
