Hello
Could anyone tell me in which LibreNMS file has the OIDs corresponding to the Ubiquiti Networks UniFi access points?
It is to test correcting a value in an OID.
From already thank you very much.
Hello
Various files, what OID is it you’re looking to correct?
I close the case.
The OID that I had obtained is not correct.
The value I am looking for is not sent by SNMP, but is calculated at source to be displayed in a proprietary web interface.
I will try to do reverse engineering to obtain it, and perhaps through extended SNMP, generate an OID that will send it to LibreNMS.
Thank you so much.
Regards
