I need to develop some monitoring option for MegaRAID, StorCLI and Dell perccli
this script should get the data from MegaRAID / StorCLI and Dell perccli and extend the snmp with thsi data and show the Storage Volume and Disks inventory and status in Librenms so I can set alert if disk failed or volume degraded
Regards,
I wish I had the time to work on this more but I can share what I have done to monitor LSI raids. I’ll be 100% frank, this relies entirely on StorCli/MegaCli. and I have had instances where StorCli would show a healthy raid set even if one of the disks was dying. So keep that in mind. In those instances I also monitor syslogs for any errors that may not present themselves to StorCli.
I use Nagios plugins heavily and I added one custom plugin called “snmp_extend.py”. You can download it here.
https://raw.githubusercontent.com/nickanderson/check_snmp_extend/master/check_snmp_extend.py
On centos, this script must be moved over to /usr/lib64/nagios/plugins/ with execute perms.
All this script does is make sure you can standardize the way extends are handled. In my snmpd.conf file on the server i want to monitor, I have the following setup to define the extend “megaraid”.
extend megaraid /opt/clinicit/megaclisas-status --nagios
This will call the “megaclisas-status” script which is a wrapper for storcli/megacli. You have to download it from here and install somewhere it can execute.
https://raw.githubusercontent.com/eLvErDe/hwraid/master/wrapper-scripts/megaclisas-status
Once you have all of these scripts in place, you can test from from command line on the librenms server to see if you are getting some responces.
[root@nms-test plugins]# ./check_snmp_extend.py --host 10.1.15.51 --snmp-version 2c --community testing123 --extend-name megaraid
RAID OK - Arrays: OK:2 Bad:0 - Disks: OK:12 Bad:0
If you got that far, you can add the service under NMS and monitor it as you see fit. Hope this helps.
Hi Kevin,
thanks!
I have OpenManage installed in one of the servers but from some reason it’s not show the RAID and disks on Librenms even it’s set correctly on snmpd.conf
FYI
We have extensive experiences in building the librenms custom module and development. Please contact us here Best Custom WHMCS Theme & Module Development Services
Anyone has experience with storcli in this context?
