I need to display the port on which the end device is connected when searching in FDB.
The problem is that if there were more devices connected to the port before, they are in the FDB table and if there is more than one, the port is not shown as EndPoint.
If I have set FDB delete for 1 day, after one day the port will show as EndPoint.
Is it possible to make the EndPoint lookup ignore older FDBs than a certain time to make the Endpoint lookup functional and at the same time to have old data to be able to find what was on the port in the past ?
In the FDB table there are two different devices, one is already disconnected.
If the disconnected one is ignored the EndPoint search would work.
Thank you
