Running through a “./validate.php” it’s telling me that my database schema may be wrong and lists a couple MySQL commands to fix. When I run the commands on the database, I get “out of range” errors though. I’m not well versed in MySQL, any help on a fix?
librenms@librenms:~$ ./daily.sh
Updating SQL-Schema OK
Cleaning up DB OK
Component Version LibreNMS 1.45-11-geea8ced DB Schema 270 PHP 7.0.32-0ubuntu0.16.04.1 MySQL 5.7.23-0ubuntu0.16.04.1 RRDTool 1.5.5 SNMP NET-SNMP 5.7.3 ==================================== [OK] Composer Version: 1.7.3 [OK] Dependencies up-to-date. [OK] Database connection successful [FAIL] Database: incorrect column (ports/ifInUcastPkts_delta) [FAIL] Database: incorrect column (ports/ifOutUcastPkts_delta) [FAIL] Database: incorrect column (ports/ifInErrors_delta) [FAIL] Database: incorrect column (ports/ifOutErrors_delta) [FAIL] Database: incorrect column (ports/ifInOctets_delta) [FAIL] Database: incorrect column (ports/ifOutOctets_delta) [FAIL] We have detected that your database schema may be wrong, please report the following to us on Discord (LibreNMS) or the community site (Report database schema issues here - LibreNMS Community): [FIX]: Run the following SQL statements to fix. SQL Statements: ALTER TABLE `ports` CHANGE `ifInUcastPkts_delta` `ifInUcastPkts_delta` bigint(20) unsigned NULL ; ALTER TABLE `ports` CHANGE `ifOutUcastPkts_delta` `ifOutUcastPkts_delta` bigint(20) unsigned NULL ; ALTER TABLE `ports` CHANGE `ifInErrors_delta` `ifInErrors_delta` bigint(20) unsigned NULL ; ALTER TABLE `ports` CHANGE `ifOutErrors_delta` `ifOutErrors_delta` bigint(20) unsigned NULL ; ALTER TABLE `ports` CHANGE `ifInOctets_delta` `ifInOctets_delta` bigint(20) unsigned NULL ; ALTER TABLE `ports` CHANGE `ifOutOctets_delta` `ifOutOctets_delta` bigint(20) unsigned NULL ;
mysql> use librenms;
Database changed
mysql> ALTER TABLEportsCHANGEifInUcastPkts_deltaifInUcastPkts_deltabigint(20) unsigned NULL ;
ERROR 1264 (22003): Out of range value for column ‘ifInUcastPkts_delta’ at row 138
mysql> ALTER TABLEportsCHANGEifOutUcastPkts_deltaifOutUcastPkts_deltabigint(20) unsigned NULL ;
ERROR 1264 (22003): Out of range value for column ‘ifOutUcastPkts_delta’ at row 138
mysql>
