Hi guys.
My oxidized web page show all device as “never” last updated.
I can change interval on config to 120 secs for instance and it does not change.
If I change the input to csv file with just a few devices is works ok but when trying with lnms api , it brings 20 devices and it takes a lot to begin going green all the devices.
Ok …
when trying with side buttons … (reload , refresh , update) nothing happens.
How can I force a device to be queried.
Any idea ?
Leandro.
Are you specifying the login details for the devices in the oxidised config file? LibreNMS doesn’t support storing them so you have to do it within Oxidized itself.
