when I add the device fortigate modelo1010 not visualize in the menu ports.
I see inventory ports.
which it is the reason why I can not see the ports
When I add the device does not generate error.
Please I need help to see the statistics of ports
post the output of ./poller.php -h HOSTNAME -d -r -f -m ports
Hi, Thanks
I post the output below.
LibreNMS 2015.master Poller
Version info:
Commit SHA:
Commit Date:
DB Schema: 118
PHP: 5.5.9-1ubuntu4.19
MySQL: 5.5.47-0ubuntu0.14.04.1
RRDTool: 1.4.7
SNMP: NET-SNMP version: 5.7.2
DEBUG!
Starting polling run:
SQL[e[0;33mSELECT device_id FROM devices WHERE disabled = 0 AND hostname LIKE ‘192.168.160.1’ ORDER BY device_id ASCe[0m]
SQL[e[0;33mSELECT * FROM devices WHERE device_id = '1’e[0m]
SQL[e[0;33mSELECT * FROM vrf_lite_cisco WHERE device_id = '1’e[0m]
SQL[e[0;33mSELECT * FROM devices_attribs WHERE device_id = '1’e[0m] 192.168.160.1 1 fortigate
SQL[e[0;33mINSERT INTO device_perf (xmt,rcv,loss,min,max,avg,device_id,timestamp) VALUES (‘3’,‘3’,‘0’,‘174’,‘177’,‘176’,‘1’,NOW())e[0m] /usr/bin/snmpget -v2c -c COMMUNITY -Oqv -m SNMPv2-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 sysObjectID.0SNMPv2-SMI::enterprises.12*
/usr/bin/snmpget -v2c -c COMMUNITY -OQnUst -m SNMPv2-MIB:HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 sysUpTime.0 sysLocation.0 sysContact.0 sysName.0 sysObjectID.0sysUpTime.0 = 28783959
sysLocation.0 = Tucuman
sysContact.0 =
sysName.0 = RT-SDM11-Tucuman
sysObjectID.0 = enterprises.12*
/usr/bin/snmpget -v2c -c COMMUNITY -OvQ -m SNMPv2-MIB:HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 sysDescr.0RT-SDM11-Tucuman
/usr/bin/snmpget -v2c -c COMMUNITY -OQnUst -m HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 snmpEngineTime.0 hrSystemUptime.0snmpEngineTime.0 = No Such Object available on this agent at this OID
hrSystemUptime.0 = No Such Object available on this agent at this OID
Using SNMP Agent Uptime (287839s)
[e[0;31mRRD Disablede[0m]RRD[e[0;32mcreate /opt/synchro/librenms/rrd/192.168.160.1/uptime.rrd --step 300 DS:uptime:GAUGE:600:0:U RRA:AVERAGE:0.5:1:2016 RRA:AVERAGE:0.5:6:1440 RRA:AVERAGE:0.5:24:1440 RRA:AVERAGE:0.5:288:1440 RRA:MIN:0.5:1:720 RRA:MIN:0.5:6:1440 RRA:MIN:0.5:24:775 RRA:MIN:0.5:288:797 RRA:MAX:0.5:1:720 RRA:MAX:0.5:6:1440 RRA:MAX:0.5:24:775 RRA:MAX:0.5:288:797 RRA:LAST:0.5:1:1440 -Oe[0m]
RRDtool Output: [e[0;31mRRD Disablede[0m]RRD[e[0;32mupdate /opt/synchro/librenms/rrd/192.168.160.1/uptime.rrd N:287839e[0m]
RRDtool Output: Uptime: 3 days, 7h 57m 19s
Load poller module ports
Caching Oids: /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifXEntryifName.1 = dmz
ifName.2 = wan1
ifName.3 = wan2
ifName.4 = modem
ifName.5 = VPN_a_CHACABUCO
ifName.6 = VPN_AZURE
ifName.7 = ssl.root
ifName.8 = internal
ifInMulticastPkts.1 = 0
ifInMulticastPkts.2 = 0
ifInMulticastPkts.3 = 0
ifInMulticastPkts.4 = 0
ifInMulticastPkts.5 = 0
ifInMulticastPkts.6 = 0
ifInMulticastPkts.7 = 0
ifInMulticastPkts.8 = 0
ifInBroadcastPkts.1 = 0
ifInBroadcastPkts.2 = 0
ifInBroadcastPkts.3 = 0
ifInBroadcastPkts.4 = 0
ifInBroadcastPkts.5 = 0
ifInBroadcastPkts.6 = 0
ifInBroadcastPkts.7 = 0
ifInBroadcastPkts.8 = 0
ifOutMulticastPkts.1 = 0
ifOutMulticastPkts.2 = 0
ifOutMulticastPkts.3 = 0
ifOutMulticastPkts.4 = 0
ifOutMulticastPkts.5 = 0
ifOutMulticastPkts.6 = 0
ifOutMulticastPkts.7 = 0
ifOutMulticastPkts.8 = 0
ifOutBroadcastPkts.1 = 0
ifOutBroadcastPkts.2 = 0
ifOutBroadcastPkts.3 = 0
ifOutBroadcastPkts.4 = 0
ifOutBroadcastPkts.5 = 0
ifOutBroadcastPkts.6 = 0
ifOutBroadcastPkts.7 = 0
ifOutBroadcastPkts.8 = 0
ifHCInOctets.1 = 0
ifHCInOctets.2 = 1991927330
ifHCInOctets.3 = 0
ifHCInOctets.4 = 0
ifHCInOctets.5 = 393756
ifHCInOctets.6 = 28937874
ifHCInOctets.7 = 0
ifHCInOctets.8 = 162363633
ifHCInUcastPkts.1 = 0
ifHCInUcastPkts.2 = 4152238
ifHCInUcastPkts.3 = 0
ifHCInUcastPkts.4 = 0
ifHCInUcastPkts.5 = 1667
ifHCInUcastPkts.6 = 133747
ifHCInUcastPkts.7 = 0
ifHCInUcastPkts.8 = 1169931
ifHCInMulticastPkts.1 = 0
ifHCInMulticastPkts.2 = 0
ifHCInMulticastPkts.3 = 0
ifHCInMulticastPkts.4 = 0
ifHCInMulticastPkts.5 = 0
ifHCInMulticastPkts.6 = 0
ifHCInMulticastPkts.7 = 0
ifHCInMulticastPkts.8 = 0
ifHCInBroadcastPkts.1 = 0
ifHCInBroadcastPkts.2 = 0
ifHCInBroadcastPkts.3 = 0
ifHCInBroadcastPkts.4 = 0
ifHCInBroadcastPkts.5 = 0
ifHCInBroadcastPkts.6 = 0
ifHCInBroadcastPkts.7 = 0
ifHCInBroadcastPkts.8 = 0
ifHCOutOctets.1 = 0
ifHCOutOctets.2 = 232301357
ifHCOutOctets.3 = 0
ifHCOutOctets.4 = 0
ifHCOutOctets.5 = 393904
ifHCOutOctets.6 = 27823954
ifHCOutOctets.7 = 0
ifHCOutOctets.8 = 1696451138
ifHCOutUcastPkts.1 = 0
ifHCOutUcastPkts.2 = 1480546
ifHCOutUcastPkts.3 = 0
ifHCOutUcastPkts.4 = 0
ifHCOutUcastPkts.5 = 1667
ifHCOutUcastPkts.6 = 114937
ifHCOutUcastPkts.7 = 0
ifHCOutUcastPkts.8 = 1458429
ifHCOutMulticastPkts.1 = 0
ifHCOutMulticastPkts.2 = 0
ifHCOutMulticastPkts.3 = 0
ifHCOutMulticastPkts.4 = 0
ifHCOutMulticastPkts.5 = 0
ifHCOutMulticastPkts.6 = 0
ifHCOutMulticastPkts.7 = 0
ifHCOutMulticastPkts.8 = 0
ifHCOutBroadcastPkts.1 = 0
ifHCOutBroadcastPkts.2 = 0
ifHCOutBroadcastPkts.3 = 0
ifHCOutBroadcastPkts.4 = 0
ifHCOutBroadcastPkts.5 = 0
ifHCOutBroadcastPkts.6 = 0
ifHCOutBroadcastPkts.7 = 0
ifHCOutBroadcastPkts.8 = 0
ifLinkUpDownTrapEnable.1 = enabled
ifLinkUpDownTrapEnable.2 = enabled
ifLinkUpDownTrapEnable.3 = enabled
ifLinkUpDownTrapEnable.4 = enabled
ifLinkUpDownTrapEnable.5 = enabled
ifLinkUpDownTrapEnable.6 = enabled
ifLinkUpDownTrapEnable.7 = enabled
ifLinkUpDownTrapEnable.8 = enabled
ifHighSpeed.1 = 0
ifHighSpeed.2 = 100
ifHighSpeed.3 = 0
ifHighSpeed.4 = 0
ifHighSpeed.5 = 100
ifHighSpeed.6 = 100
ifHighSpeed.7 = 0
ifHighSpeed.8 = 0
ifPromiscuousMode.1 = false
ifPromiscuousMode.2 = false
ifPromiscuousMode.3 = false
ifPromiscuousMode.4 = false
ifPromiscuousMode.5 = false
ifPromiscuousMode.6 = false
ifPromiscuousMode.7 = false
ifPromiscuousMode.8 = false
ifConnectorPresent.1 = true
ifConnectorPresent.2 = true
ifConnectorPresent.3 = true
ifConnectorPresent.4 = true
ifConnectorPresent.5 = false
ifConnectorPresent.6 = false
ifConnectorPresent.7 = false
ifConnectorPresent.8 = false
ifAlias.1 =
ifAlias.2 = ARLAB
ifAlias.3 =
ifAlias.4 =
ifAlias.5 =
ifAlias.6 =
ifAlias.7 = SSL VPN interface
ifAlias.8 =
ifCounterDiscontinuityTime.1 = 0:0:00:00.00
ifCounterDiscontinuityTime.2 = 0:0:00:00.00
ifCounterDiscontinuityTime.3 = 0:0:00:00.00
ifCounterDiscontinuityTime.4 = 0:0:00:00.00
ifCounterDiscontinuityTime.5 = 0:0:00:00.00
ifCounterDiscontinuityTime.6 = 0:0:00:00.00
ifCounterDiscontinuityTime.7 = 0:0:00:00.00
ifCounterDiscontinuityTime.8 = 0:0:00:00.00
ifDescr /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifDescrifDescr.1 =
ifDescr.2 =
ifDescr.3 =
ifDescr.4 =
ifDescr.5 =
ifDescr.6 =
ifDescr.7 =
ifDescr.8 =
ifAdminStatus /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifAdminStatusifAdminStatus.1 = up
ifAdminStatus.2 = up
ifAdminStatus.3 = down
ifAdminStatus.4 = down
ifAdminStatus.5 = up
ifAdminStatus.6 = up
ifAdminStatus.7 = up
ifAdminStatus.8 = up
ifOperStatus /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifOperStatusifOperStatus.1 = down
ifOperStatus.2 = up
ifOperStatus.3 = down
ifOperStatus.4 = down
ifOperStatus.5 = up
ifOperStatus.6 = up
ifOperStatus.7 = up
ifOperStatus.8 = up
ifType /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifTypeifType.1 = ethernetCsmacd
ifType.2 = ethernetCsmacd
ifType.3 = ethernetCsmacd
ifType.4 = ethernetCsmacd
ifType.5 = tunnel
ifType.6 = tunnel
ifType.7 = tunnel
ifType.8 = bridge
ifPhysAddress /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifPhysAddressifPhysAddress.1 = 8:5b:e:cf:31:b3
ifPhysAddress.2 = 8:5b:e:cf:31:b4
ifPhysAddress.3 = 8:5b:e:cf:31:b5
ifPhysAddress.4 = 0:0:0:0:0:0
ifPhysAddress.5 =
ifPhysAddress.6 =
ifPhysAddress.7 =
ifPhysAddress.8 =
ifMtu /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifMtuifMtu.1 = 1500
ifMtu.2 = 1500
ifMtu.3 = 1500
ifMtu.4 = 1500
ifMtu.5 = 1500
ifMtu.6 = 1500
ifMtu.7 = 1500
ifMtu.8 = 1500
ifInErrors /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifInErrorsifInErrors.1 = 0
ifInErrors.2 = 0
ifInErrors.3 = 0
ifInErrors.4 = 0
ifInErrors.5 = 0
ifInErrors.6 = 0
ifInErrors.7 = 0
ifInErrors.8 = 0
ifOutErrors /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifOutErrorsifOutErrors.1 = 0
ifOutErrors.2 = 0
ifOutErrors.3 = 0
ifOutErrors.4 = 0
ifOutErrors.5 = 8
ifOutErrors.6 = 7
ifOutErrors.7 = 0
ifOutErrors.8 = 0
ifInDiscards /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifInDiscardsifInDiscards.1 = 0
ifInDiscards.2 = 0
ifInDiscards.3 = 0
ifInDiscards.4 = 0
ifInDiscards.5 = 0
ifInDiscards.6 = 0
ifInDiscards.7 = 0
ifInDiscards.8 = 0
ifOutDiscards /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 ifOutDiscardsifOutDiscards.1 = 0
ifOutDiscards.2 = 0
ifOutDiscards.3 = 0
ifOutDiscards.4 = 0
ifOutDiscards.5 = 0
ifOutDiscards.6 = 0
ifOutDiscards.7 = 0
ifOutDiscards.8 = 0
dot3StatsDuplexStatus/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m EtherLike-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 dot3StatsDuplexStatusdot3StatsDuplexStatus.1 = halfDuplex
dot3StatsDuplexStatus.2 = fullDuplex
dot3StatsDuplexStatus.3 = halfDuplex
dot3StatsDuplexStatus.4 = 0
dot3StatsDuplexStatus.5 = 0
dot3StatsDuplexStatus.6 = 0
dot3StatsDuplexStatus.7 = 0
dot3StatsDuplexStatus.8 = fullDuplex
SQL[e[0;33mSELECT COUNT(*) FROM ports WHERE device_id = ‘1’ AND ifType = 'adsl’e[0m] /usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m Q-BRIDGE-MIB -M /opt/synchro/librenms/mibs udp:HOSTNAME:161 dot1qPortVlanTabledot1qPortVlanTable = No Such Object available on this agent at this OID
Array
[1] => Array
[ifName] => dmz
[ifInMulticastPkts] => 0
[ifInBroadcastPkts] => 0
[ifOutMulticastPkts] => 0
[ifOutBroadcastPkts] => 0
[ifHCInOctets] => 0
[ifHCInUcastPkts] => 0
[ifHCInMulticastPkts] => 0
[ifHCInBroadcastPkts] => 0
[ifHCOutOctets] => 0
[ifHCOutUcastPkts] => 0
[ifHCOutMulticastPkts] => 0
[ifHCOutBroadcastPkts] => 0
[ifLinkUpDownTrapEnable] => enabled
[ifHighSpeed] => 0
[ifPromiscuousMode] => false
[ifConnectorPresent] => true
[ifAlias] =>
[ifCounterDiscontinuityTime] => 0:0:00:00.00
[ifDescr] =>
[ifAdminStatus] => up
[ifOperStatus] => down
[ifType] => ethernetCsmacd
[ifPhysAddress] => 8:5b:e:cf:31:b3
[ifMtu] => 1500
[ifInErrors] => 0
[ifOutErrors] => 0
[ifInDiscards] => 0
[ifOutDiscards] => 0
[dot3StatsDuplexStatus] => halfDuplex
[2] => Array
[ifName] => wan1
[ifHCInOctets] => 1991927330
[ifHCInUcastPkts] => 4152238
[ifHCOutOctets] => 232301357
[ifHCOutUcastPkts] => 1480546
[ifHighSpeed] => 100
[ifAlias] => ARLAB
[ifDescr] =>
[ifOperStatus] => up
[ifPhysAddress] => 8:5b:e:cf:31:b4
[ifMtu] => 1500
[ifInErrors] => 0
[ifOutErrors] => 0
[ifInDiscards] => 0
[dot3StatsDuplexStatus] => fullDuplex
[3] => Array
[ifName] => wan2
[ifHCInOctets] => 0
[ifHighSpeed] => 0
[ifAlias] =>
[ifDescr] =>
[ifAdminStatus] => down
[ifPhysAddress] => 8:5b:e:cf:31:b5
[ifMtu] => 1500
[ifInErrors] => 0
[ifOutErrors] => 0
[ifInDiscards] => 0
[4] => Array
[ifName] => modem
[ifHCInOctets] => 0
[ifHighSpeed] => 0
[ifAlias] =>
[ifDescr] =>
[ifPhysAddress] => 0:0:0:0:0:0
[ifMtu] => 1500
[ifInErrors] => 0
[ifOutErrors] => 0
[ifInDiscards] => 0
[dot3StatsDuplexStatus] => 0
[5] => Array
[ifName] => VPN_a_CHACABUCO
[ifHCInOctets] => 393756
[ifHCInUcastPkts] => 1667
[ifHCOutOctets] => 393904
[ifHCOutUcastPkts] => 1667
[ifConnectorPresent] => false
[ifAlias] =>
[ifDescr] =>
[ifType] => tunnel
[ifPhysAddress] =>
[ifMtu] => 1500
[ifInErrors] => 0
[ifOutErrors] => 8
[ifInDiscards] => 0
[6] => Array
[ifName] => VPN_AZURE
[ifHCInOctets] => 28937874
[ifHCInUcastPkts] => 133747
[ifHCOutOctets] => 27823954
[ifHCOutUcastPkts] => 114937
[ifAlias] =>
[ifDescr] =>
[ifType] => tunnel
[ifPhysAddress] =>
[ifMtu] => 1500
[ifInErrors] => 0
[ifOutErrors] => 7
[ifInDiscards] => 0
[7] => Array
[ifName] => ssl.root
[ifHCInOctets] => 0
[ifHighSpeed] => 0
[ifAlias] => SSL VPN interface
[ifDescr] =>
[ifType] => tunnel
[ifPhysAddress] =>
[ifMtu] => 1500
[ifInErrors] => 0
[ifOutErrors] => 0
[ifInDiscards] => 0
[8] => Array
[ifName] => internal
[ifHCInOctets] => 162363633
[ifHCInUcastPkts] => 1169931
[ifHCOutOctets] => 1696451138
[ifHCOutUcastPkts] => 1458429
[ifHighSpeed] => 0
[ifAlias] =>
[ifDescr] =>
[ifType] => bridge
[ifPhysAddress] =>
[ifMtu] => 1500
[ifInErrors] => 0
[ifOutErrors] => 0
[ifInDiscards] => 0
SQL[e[0;33mSELECT name FROM port_association_mode WHERE pom_id = '1’e[0m]
SQL[e[0;33mSELECT *, ports_statistics.port_id AS ports_statistics_port_id, ports.port_id AS port_id FROM ports LEFT OUTER JOIN ports_statistics ON ports.port_id = ports_statistics.port_id WHERE ports.device_id = ‘1’ ORDER BY ports.port_ide[0m]
SQL[e[0;33mUPDATE ports set deleted =‘1’ WHERE port_id = ''e[0m]
Runtime for poller module ‘ports’: 5.6765007972717 seconds
Unload poller module ports
[e[0;31mRRD Disablede[0m]RRD[e[0;32mcreate /opt/synchro/librenms/rrd/192.168.160.1/poller-perf-ports.rrd --step 300 DS:poller:GAUGE:600:0:U RRA:AVERAGE:0.5:1:2016 RRA:AVERAGE:0.5:6:1440 RRA:AVERAGE:0.5:24:1440 RRA:AVERAGE:0.5:288:1440 RRA:MIN:0.5:1:720 RRA:MIN:0.5:6:1440 RRA:MIN:0.5:24:775 RRA:MIN:0.5:288:797 RRA:MAX:0.5:1:720 RRA:MAX:0.5:6:1440 RRA:MAX:0.5:24:775 RRA:MAX:0.5:288:797 RRA:LAST:0.5:1:1440 -Oe[0m]
RRDtool Output: [e[0;31mRRD Disablede[0m]RRD[e[0;32mupdate /opt/synchro/librenms/rrd/192.168.160.1/poller-perf-ports.rrd N:5.6765007972717e[0m]
RRDtool Output:
SQL[e[0;33mSELECT * FROM device_groups ORDER BY namee[0m]
SQL[e[0;33mSELECT device_group_id FROM device_group_device WHERE device_id='1’e[0m] [e[0;31mRRD Disablede[0m]RRD[e[0;32mcreate /opt/synchro/librenms/rrd/192.168.160.1/poller-perf.rrd --step 300 DS:poller:GAUGE:600:0:U RRA:AVERAGE:0.5:1:2016 RRA:AVERAGE:0.5:6:1440 RRA:AVERAGE:0.5:24:1440 RRA:AVERAGE:0.5:288:1440 RRA:MIN:0.5:1:720 RRA:MIN:0.5:6:1440 RRA:MIN:0.5:24:775 RRA:MIN:0.5:288:797 RRA:MAX:0.5:1:720 RRA:MAX:0.5:6:1440 RRA:MAX:0.5:24:775 RRA:MAX:0.5:288:797 RRA:LAST:0.5:1:1440 -Oe[0m]
RRDtool Output: [e[0;31mRRD Disablede[0m]RRD[e[0;32mupdate /opt/synchro/librenms/rrd/192.168.160.1/poller-perf.rrd N:7.120e[0m]
RRDtool Output: [e[0;31mRRD Disablede[0m]RRD[e[0;32mcreate /opt/synchro/librenms/rrd/192.168.160.1/ping-perf.rrd --step 300 DS:ping:GAUGE:600:0:65535 RRA:AVERAGE:0.5:1:2016 RRA:AVERAGE:0.5:6:1440 RRA:AVERAGE:0.5:24:1440 RRA:AVERAGE:0.5:288:1440 RRA:MIN:0.5:1:720 RRA:MIN:0.5:6:1440 RRA:MIN:0.5:24:775 RRA:MIN:0.5:288:797 RRA:MAX:0.5:1:720 RRA:MAX:0.5:6:1440 RRA:MAX:0.5:24:775 RRA:MAX:0.5:288:797 RRA:LAST:0.5:1:1440 -Oe[0m]
RRDtool Output: [e[0;31mRRD Disablede[0m]RRD[e[0;32mupdate /opt/synchro/librenms/rrd/192.168.160.1/ping-perf.rrd N:176e[0m]
RRDtool Output: Polled in 7.120 seconds
Updating 192.168.160.1
SQL[e[0;33mUPDATE devices set uptime =‘287839’,last_ping =NOW(),last_ping_timetaken =‘176’,last_polled =NOW(),last_polled_timetaken =‘7.120’ WHERE device_id = '1’e[0m] UPDATED!
SQL[e[0;33mSELECT alert_schedule.schedule_id FROM alert_schedule LEFT JOIN alert_schedule_items ON alert_schedule.schedule_id=alert_schedule_items.schedule_id WHERE ( alert_schedule_items.target = ‘1’ ) && NOW() BETWEEN alert_schedule.start AND alert_schedule.end LIMIT 1e[0m]
SQL[e[0;33mSELECT alert_rules.* FROM alert_rules LEFT JOIN alert_map ON alert_rules.id=alert_map.rule WHERE alert_rules.disabled = 0 && ( (alert_rules.device_id = -1 || alert_rules.device_id = ‘1’ ) || alert_map.target = ‘1’ )e[0m]
SQL[e[0;33mINSERT INTO perf_times (type,doing,start,duration,devices,poller) VALUES (‘poll’,‘192.168.160.1’,‘1473653264.057’,‘7.174’,‘1’,‘mon-synchro.of1.net\n’)e[0m] ./poller.php 192.168.160.1 2016-09-12 01:07:51 - 1 devices polled in 7.174 secs
MySQL: Cell[1/0s] Row[6/0s] Rows[8/0s] Column[3/0s] Update[2/0.03s] Insert[2/0.06s] Delete[0/0s]
Can you help me? Thanks
