FortiGate firewalls identified as Ubiquiti EdgeSwitch
I am having trouble adding my FortiGate firewalls to a brand new LibreNMS install (26.1.0-dev.2+fa8b459e2). All devices are running the same FW version (7.2.10) but different hardware 201E, 2000E, 301E, 501E etc. After adding the device SNMPv2 the detected OS is EdgeSwitch. The serial number, uptime, location are all pulled and are correct. I am monitoring these firewalls from other SNMP tools ie LogicMonitor without any issues.
image1230×386 23.1 KB
You need to provide the information asked for when you went to create this request.
READ THIS FIRST:
Questions about *plugins* such as *Weathermap* should be posted in the Plugins category!!
https://community.librenms.org/c/plugins/15
./discovery.php -h HOSTNAME -d | curl --data-binary @- https://paste.rs/
./poller.php -h HOSTNAME -r -f -d | curl --data-binary @- https://paste.rs/
If you need to post any text longer than a few lines, please use a “pastebin” service, we recommend using https://paste.rs/ or https://paste.sh/
Hello laf,
Sorry I did not include all the info, I left it out because it seems to be ok….
LibreNMS 26.1.0-dev.2+fa8b459e2 (2025-12-16T10:46:39-06:00)
DB Schema 2025_12_05_205509_devices_add_mtu_status (362)
PHP 8.3.6
Python 3.12.3
Database MariaDB 10.11.13-MariaDB-0ubuntu0.24.04.1
SNMP 5.9.4.pre2
[OK] Composer Version: 2.9.2
I believe I have resolved the issue however I cannot understand why. I removed the SNMP Agent details on the firewall and rediscovered the device and now its detected properly.
