Dear All,
I cannot get trought this issue so a little help or suggestions would be appreciated here
We’ve been performing a partition extension and a restart on one lnms server. All went well.
After this restart we couldn’t logged in again : a deactivation of Selinux (set to permissive mode) solved the issue.
However since then we observed some polling gaps and alerts devices down for few juniper devices (os junos, SRX300). After investigations, it seems there is no network nor devices issues.
What generate those gaps and alerts is that Fping failed intermittently.
What’s suprising is that it’s not happening for all devices but only for some junos
=> When trying to launch fping directly in cli, no losses seen
[librenms-1 log]# ‘/usr/sbin/fping’ ‘-e’ ‘-q’ ‘-c’ ‘4’ ‘-p’ ‘600’ ‘-t’ ‘600’ ‘XX.XX.XX.XX’
172.22.38.133 : xmt/rcv/%loss = 4/4/0%, min/avg/max = 4.41/5.65/6.41
=> with a permanent ping running for hours from the server : no packet loss at all.
losses are seen only in cron/polling logs from impacted devices
here is an excerpt when it happens (with IP replaced by XX)
*Attempting to initialize OS: junos *
*OS initialized: LibreNMS\OS\Junos *
Hostname: XX.XX.XX.XX
Device ID: 282
OS: junos
*SQL[e[1;33mselect hostname
, overwrite_ip
from devices
where hostname
= ? limit 1 e[0;33m[“XX.XX.XX.XX”]e[0m 0.47ms] *
[FPING] ‘/usr/sbin/fping’ ‘-e’ ‘-q’ ‘-c’ ‘4’ ‘-p’ ‘600’ ‘-t’ ‘600’ ‘XX.XX.XX.XX’
*response: {“xmt”:4,“rcv”:0,“loss”:100,“min”:0.0,“max”:0.0,“avg”:0.0,“dup”:0,“exitcode”:1} *
SQL[e[1;33mselect device_groups
., device_group_device
.device_id
as pivot_device_id
.device_group_id
as pivot_device_group_id
from device_groups
inner join device_group_device
on device_groups
.id
= device_group_device
.device_group_id
where device_group_device
.device_id
= ? e[0;33m[282]e[0m 0.8ms] *
*SQL[e[1;33mselect exists(select * from alert_schedule
where (start
<= ? and end
>= ? and (recurring
= ? or (recurring
= ? and ((time(start
) < time(end
) and time(start
) <= ? and time(end
) > ?) or (time(start
) > time(end
) and (time(end
) <= ? or time(start
) > ?))) and (recurring_day
like ? or recurring_day
is null)))) and (exists (select * from devices
inner join alert_schedulables
on devices
.device_id
= alert_schedulables
.alert_schedulable_id
where alert_schedule
.schedule_id
.schedule_id
and alert_schedulables
.alert_schedulable_type
= ? and alert_schedulables
= ?) or exists (select * from device_groups
on device_groups
.id
.schedule_id
.schedule_id
in (?, ?)))) as exists
e[0;33m[“2022-04-04T16:59:55.389187Z”,“2022-04-04T16:59:55.389187Z”,0,1,“16:59:55”,“16:59:55”,“16:59:55”,“16:59:55”,“e[41m%”,“device”,282,“device_group”,3,40]e[0m 1.08ms] *
*SQL[e[1;33mINSERT IGNORE INTO device_perf
(xmt
,rcv
,loss
,min
,max
,avg
,device_id
,timestamp
,debug
) VALUES (:xmt,:rcv,:loss,:min,:max,:avg,:device_id,NOW(),:debug) e[0;33m{“xmt”:4,“rcv”:0,“loss”:100,“min”:0,“max”:0,“avg”:0,“device_id”:282,“debug”:"[]"}e[0m 1.65ms] *
UnpingableSQL[e[1;33mUPDATE devices
set status
=?,status_reason
=? WHERE device_id=? e[0;33m[“0”,“icmp”,282]e[0m 1.65ms]
We tried to deactivate Selinux completely but it did not improved the behavior.
./validate.php
Component | Version |
LibreNMS | 21.6.1-4-gd62bf9e3f |
DB Schema | 2021_25_01_0127_create_isis_adjacencies_table (210) |
PHP | 7.4.20 |
Python | 3.6.8 |
MySQL | 10.5.10-MariaDB |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 2.3.3
[INFO] Detected Python Wrapper
Modified Files:
config.php
Have one you ever faced those kind of issues ?
Could suggest alternative tests ?
Simba
