sewkol
28 October 2020 09:33
1
Hello
Fresh install from ova. I added 5 devices and everything looks ok. Next day (after daily update?) I have blank page from WebUI.
Validate install:
root@librenms:~# sudo /opt/librenms/validate.php
In PackageManifest.php line 122:
Undefined index: name
> Component
Version
LibreNMS
1.63-57-g0040f38d1
DB Schema
Not Connected (0)
PHP
7.2.24-0ubuntu0.18.04.7
Python
3.6.9
MySQL
RRDTool
1.7.0
SNMP
NET-SNMP 5.7.3
[OK] Composer Version: 2.0.2
root@librenms:~#
Daily update from cli:
librenms@librenms:~$ ./daily.sh
Updating SQL-Schema OK
Cleaning up DB OK
I tried update system, but this dosen’t help. Any ideas?
SK
sewkol
28 October 2020 16:55
2
I reinstall all once again. After deploy LibreNMS works ok. I update operating system and still ok. After ./daily.sh a have blank screen on web.
Updating to latest release OK
Python 3 dependencies missing, switched to php71-python2 branch. OK
Updating Composer packages OK
Updated from 1.63 to 1.68 OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
I think PHP 7.1 is not supported anymore. Try to switch to 7.4
sewkol
29 October 2020 11:13
4
I installed PHP 7.4 with all required packages - still the same problem.
Any errors in the Webserver log?
sewkol
30 October 2020 08:48
6
Finally, I found a solution - you need to update PHP before running ./daily.php . Below are the steps to follow:
Update system
apt update
apt upgrade
reboot
Add PHP Repository
sudo apt-get update
sudo apt -y install software-properties-common
sudo add-apt-repository ppa:ondrej/php
sudo apt-get update
Install PHP 7.4
sudo apt -y install php7.4
Install required packages
sudo apt install acl curl composer fping git graphviz imagemagick mariadb-client mariadb-server mtr-tiny nginx-full nmap php7.4-cli php7.4-curl php7.4-fpm php7.4-gd php7.4-json php7.4-mbstring php7.4-mysql php7.4-snmp php7.4-xml php7.4-zip rrdtool snmp snmpd whois unzip python3-pymysql python3-dotenv python3-redis python3-setuptools
Set timezone for php...
sudo vi /etc/php/7.4/fpm/php.ini
sudo vi /etc/php/7.4/cli/php.ini
...and system:
sudo timedatectl set-timezone Europe/Warsaw
Update LibreNMS nginix conf file
sudo vi /etc/nginx/conf.d/librenms.conf
fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
Restart services
sudo systemctl restart mariadb
sudo systemctl restart nginx
sudo service php7.4-fpm restart
Looks like the system is working. Passes ./validate.php and updates ./daily.php without errors.
LibreNMS | 1.68
DB Schema | 2020_09_22_172321_add_alert_log_index (174)
PHP | 7.4.11
Python | 3.6.9
MySQL | 10.1.47-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 2.0.3
I think it’s time to create a new VM
Thanks Jarod2801 for the hint.
SK
