Fresh install - not working
Preface: I am quite new to Linux and working with tools of this nature
I followed the instructions exactly as seen here Installing LibreNMS - LibreNMS Docs for Ubuntu. I did have an issue with the below script (for PHP dependencies) and had to use the global workaround - which was successful. I did omit the Cron job step as well as I was going to go a different route there.
su - librenms
exit
Now, I am stuck at the Web Installer step. When I try to access the server via remote browser, I get error 500 as seen in the remote-browser attached screenshot. When I try to access it from the server’s browser, I get a blank web page (see host-browser screenshot). However, I do see the LibreNMS logo on the page tab.
I can not proceed from this step. Any help?
Edit: had to add the two other screenshots as replied due to being new user
please check PHP or Apache config,When you use nginx installation mode, please check nginx config
I checked the conf.d file in the nginx directory for my site and the output is below. Looks okay to me but I am far from an expert.
I also found the below error in the nginx error log file
*2021/11/24 15:50:01 [error] 19490#19490: 1 FastCGI sent in stderr: “PHP message: PHP Warning: require(/opt/librenms/html/…/vendor/autoload.php): failed to open stream: No such file or directory in /opt/librenms/html/index.php on line 34PHP message: PHP Fatal error: require(): Failed opening required ‘/opt/librenms/html/…/vendor/autoload.php’ (include_path=’.:/usr/share/php’) in /opt/librenms/html/index.php on line 34” while reading response header from upstream, client: x.x.x.x, server: x.x.x.x, request: “GET / HTTP/1.1”, upstream: “fastcgi://unix:/run/php-fpm-librenms.sock:”, host: “x.x.x.x”
This says you didn’t run the composer step
When I ran that step I get the below exception despite running all the previous steps by-the-book and successfully. When I do the proposed global workaround, that appears to go successful. However, perhaps I am overlooking something or missing an implied step. Any idea?
Fixed. Was in the wrong directory when installing the composer. Took the installation steps too litreral. Thanks for all the help!
