Hi there,
When I have almost finished fresh install on Centos 7 with Apache, on stage 2 I have the following error:
Unauthorized
Files .env and config.php.default are ok. I can login into DB with librenms user.
Any idea?
Thanks in advance
Hi there,
Unauthorized
Any idea?
Thanks in advance
If you put all the settings in “config.php.default”,copy the file to config.php in the same directory. If still no luck, try checking /opt/librenms/logs/librenms.log
Hello Chas, thanks for the reply,
We tried to copy and edit config.php.copy to config.php and when I try to access to librenms.com/install.php, redirect to librenms.com/login and shows me 404 not found…
The requested URL /login was not found on this server.
Is this the doc you followed? https://docs.librenms.org/Installation/Installation-CentOS-7-Apache/
Check base_url is set to default “/” in config.php
If you use a reverse proxy see here https://docs.librenms.org/Support/FAQ/#my-reverse-proxy-is-not-working
can you post output of
./validate.php
and contents of config.php and apache config.
Yes, I followed this documentation
config.php
$config[‘db_host’] = ‘localhost’;
$config[‘db_port’] = ‘3306’;
$config[‘db_user’] = ‘librenms’;
$config[‘db_pass’] = ‘password’;
$config[‘db_name’] = ‘librenms’;
$config[‘user’] = ‘librenms’;
$config[‘base_url’]= “/”;
$config[‘auth_mechanism’] = “mysql”; # default, other options: ldap, http-auth
$config[‘http_auth_guest’] = “guest”;
$config[‘rrd_purge’] = 0;
$config[‘enable_billing’] = 1;
$config[‘show_services’] = 1;
Component | Version |
LibreNMS | 1.56-16-gae84049 |
DB Schema | 2019_10_03_211702_serialize_config (144) |
PHP | 7.2.22 |
MySQL | 10.3.18-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.9.0
[WARN] You have not added any devices yet.
You can add a device in the webui or with ./addhost.php
Modified Files:
LibreNMS/Alert/Transport/Mattermost.php
LibreNMS/Alert/Transport/Opsgenie.php
LibreNMS/OS/ArrisDsr4410md.php
addhost.php
adduser.php
alerts.php
artisan
billing-calculate.php
build-base.php
check-services.php
config.php.default
config_to_json.php
contrib/convert-mib-graphs.sh
contrib/findit
cronic
and 118 more…
apache
<VirtualHost *:80>
DocumentRoot /opt/librenms/html/
ServerName librenms.example.com
AllowEncodedSlashes NoDecode
<Directory /opt/librenms/html/>
Require all granted
< /Directory>
< /VirtualHost>
hmm not too sure how so many files can become modified,
I would try
./scripts/github-remove
chown -R librenms:librenms /opt/librenms
./daily.sh
- check outputsestatus
and if selinux is enforcing then you need to run those commands in the docs or turn it off.
