Hi there, here is the output of my ./validate.php
| LibreNMS | 24.7.0 (2024-07-17T08:35:08+02:00) |
| DB Schema | 2024_07_13_133839_modify_ent_physical_defaults (295) |
| PHP | 8.1.13 |
| Python | 3.6.9 |
| Database | MariaDB 10.5.15-MariaDB-1:10.5.15+maria~bionic |
| RRDTool | 1.7.0 |
| SNMP | 5.7.3 |
[OK] Composer Version: 2.7.7
My fullscreenmap was not working for some time and yesterday I took a look to try to find what the deal is, I found in my browsers console some erros about a reference that was misleading at fist but when I looked at the line generating the error in the rendered html I found that some devices had a " ’ " character that breaks the js, as a quick workaround I changed the hostnames removing the culprit character and that fixed fullscreenmap.
I thought that sharing this may help some poeple facing the same problem
BR
