Hello, I need your help!
I start in the network administrator job and it’s the first time I use Librenms.
In Librenms, in all or almost graph have gaps.
I have read a lot of documentation, but I have not got the solution.
Librenms turn in a VM.
I use Firefox Version 61.0.1 (64 bits) for seeing the interface web of Librenms.
Are you using Network storage on your VM like a SAN ? Check atop and see if your system is waiting on disk. RRDCached in-particular will cause high IO and your CPU will be always waiting on writing to disk, causing GAPS in the graphs. In my case, moving it from a VM to a standalone box fixed this.
Check the health of your VM, CPU and RAM, and increase resources to it, see if the GAPS improve.
For that device, check Graphs -> Poller and see if your SNMP polling is spiking at the same times.
@NicoChoq The first thing is to add (if not added already) the librenms itself to monitor.
That way you will be able to check cpu/ram/diskIO in a friendly way.
