It’d be nice to be able to attach a name to a geolocation [lat, long] title, just for recognition of the location.
And if that’s already able to be done, I have not found it… Could someone please post?
TIA!
TIA!
Yes its under yourlibrenms.org/locations
Yes, I found where the list is, but I cannot figure out how to change the name from the [lat,long] to another name…
Ah…
To make this more clear to others that may be watching:
Put the “common name” or “descriptive name” in the “Override sysLocation” field. This will create a new location, that you can then edit and change the Lat/Long under the “Devices -> Geolocations -> All locations” menu.
Thanks for the help, Kevin!
Closed as this has already implanted.
