running LibreNMS for a couple years now, but since a while the global settings menu is broken.
Opening the global settings gives me the top bar and just @routes
The Chrome browser console shows the following error:
Uncaught ReferenceError: route is not defined
at Module.bUC5 (app.js?id=d074dd82ac08dba78c44:1)
at l (manifest.js?id=3c768977c2574a34506e:1)
at Object.0 (app.js?id=d074dd82ac08dba78c44:1)
at t (manifest.js?id=3c768977c2574a34506e:1)
at Array.r [as push] (manifest.js?id=3c768977c2574a34506e:1)
at app.js?id=d074dd82ac08dba78c44:1
Other users of the system have the same error.
Other browsers give me the same problem
Component
Version
LibreNMS
1.58.1-48-ga1f4b1b88
DB Schema
2019_04_22_220000_update_route_table (147)
PHP
7.2.24-0ubuntu0.18.04.1
MySQL
10.1.43-MariaDB-0ubuntu0.18.04.1
RRDTool
1.7.0
SNMP
NET-SNMP 5.7.3
[OK] Composer Version: 1.9.1
I tried changing my apache config, changed the hostname to the FQDN, to the hostname only, or even to an IP address, non if which solve this problem.
Also, this setup has been running for at least 3 years without this problem.
There is no base_url set in the config.php.
If I set base_url to “/” I still have the same problem.
[dan@besser:/usr/local/www/librenms] $ sudo ./validate.php
PHP Deprecated: Array and string offset access syntax with curly braces is deprecated in /usr/local/www/librenms/includes/functions.php on line 1833
PHP Deprecated: Array and string offset access syntax with curly braces is deprecated in /usr/local/www/librenms/includes/functions.php on line 2336
sh: git: not found
sh: git: not found
LibreNMS | 1.61
DB Schema | 2020_02_10_223323_create_alert_location_map_table (159)
PHP | 7.4.3
MySQL | 5.7.29
RRDTool | 1.7.2
SNMP | NET-SNMP 5.7.3
[WARN] fping FAILURES can be ignored if running LibreNMS in a jail without ::1. You may want to test it manually: fping ::1
[FAIL] fping could not be executed. fping must have CAP_NET_RAW capability (getcap) or suid. Selinux exlusions may be required.
(This account is currently not available.)
[FAIL] fping6 could not be executed. fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exlusions may be required.
