Global vs device alerts
Hi
I want to alert when disk usage is over some limits on all of my systems.
I have this global rule applied to all devices: “stotage.storage_perc >= 80” (level warn) to detect filling file systems.
On some systems i accept higher disk usage, so I added this device rule: “storage.storage_perc >= 90” applied to one device.
The problem is that the global rules triggers an alert even on the device with a separate device rule. Usage is at 82%.
What have I misunderstood?
BC, ur global alert rule also apply for the solo one u made.
But the slide under it, all exept this group,
So u make an group for that type alert , example exclusie 80% disk tule.
Set that device in there and Mark them on the all exept this groupe of device.
Next u make an seperate rule for 90% only in that group.
Hope u understand me lol.
Cheers
Roy
You could also use the warn value that you can set per-device.
Device -> Edit -> Storage
Set the % Warn.
Then, in you alert rule storage.storage_perc >= storage.storage_perc_warn
You can also set the default % Warn for storage when adding new devices:
From https://docs.librenms.org/Support/Configuration/
$config['storage_perc_warn'] = 60;
$config['os']['linux']['storage_perc_warn'] = 60;
@TheGreatDoc. This suggestion works for me. Thanks!
