Globally disabled module settings are superseded by OS settings
Where do I modify OS defaults without breaking auto-update?
I am using LibreNMS to poll specific interfaces and response time counts, so i’d like all the modules i dont want turned off without resorting to clicking in the gui many times per device
I used “lnms config:set” to configure global preferences but this doesn’t seem to override OS module preference
lnms config:set os.<name>.poller_modules.<module> <true|false>
for example:
lnms config:set os.iosxr.poller_modules.cipsec-tunnels false
If you want to check the current os settings:
lnsm config:get os.iosxr.poller_modules
(also as a note, most poller modules don’t take up any poller time if no data is discovered)
Thank you sir!
Is there also a way to disable polling on ports by default? That way I can enable polling on select ports?
Thanks,
That doc isn’t updated yet, but it would be lnms config:set os.ios.polling.selected_ports true to set per OS.
