GPSD Application Problem
Good day and thank you for your attention. I’m having an issue with the LibreNMS GPSD application extension. I am running gpsd on a Raspberry Pi 3 Model B Plus Rev 1.3, with 6.6.31+rpt-rpi-v8 (Debian 12.6). When I download the script and run it from the command line ($ sudo ./gpsd), the script seems to hang in the background (no output to the terminal). After waiting as much as five minutes for something to happen, I broke the script with CTRL-C. When I did that, the following was spit out to the terminal:
^Ccat: /tmp/tmp.Rw3r5DfdU2: No such file or directory
Traceback (most recent call last):
  File "<string>", line 1, in <module>
  File "/usr/lib/python3.11/json/__init__.py", line 293, in load
    return loads(fp.read(),
  File "/usr/lib/python3.11/json/__init__.py", line 346, in loads
    return _default_decoder.decode(s)
  File "/usr/lib/python3.11/json/decoder.py", line 337, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib/python3.11/json/decoder.py", line 355, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
{"data":{"mode":"", "hdop":"", "vdop":"", "latitude":"", "longitude":"", "altitude":"", "satellites":"", "satellites_used":""}, "error":"0", "errorString":"", "version":""}
rm: cannot remove '/tmp/tmp.Rw3r5DfdU2': No such file or directory
Any ideas? Thanks in advance!
NEVERMIND
I had managed to break my gpsd service and didn’t even realize it. Always check for the obvious problems first!
NOW the problem is the GPSD Application graphs in LibreNMS will not populate. When I run the gpsd application script manually from the command line, I notice that it takes about six seconds for the information to show up. I have a suspicion there is a time-out in snmpd that is being exceeded. Maybe someone knows?
$ ./gpsd
{"data":{"mode":"3", "hdop":"1.01", "vdop":"1.66", "latitude":"33.000000000", "longitude":"-117.000000000", "altitude":"28.3", "satellites":"10", "satellites_used":"8"}, "error":"0", "errorString":"", "version":"3.22"}
It took 6 seconds for this script to execute.
