Hello everyone here is my problem
my graphics remain empty my rights his good my validate.php
from which side to search rrdtool?
here are my settings
Debian 9.4
mysql apache2
| LibreNMS | 1.43-141-g7c45cd5f6 |
| DB Schema | 268 |
| PHP | 7.0.30-0+deb9u1 |
| MySQL | 10.1.26-MariaDB-0+deb9u1 |
| RRDTool | 1.6.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.2
[FIX] Check your poll log and see: http://docs.librenms.org/Support/Performance/
Devices:
primaire-voltaire
esapce_valles
bib-langevin
stade_frachon
ccas_cos
[FIX] sudo chown -R librenms:librenms /opt/librenms
Files:
/opt/librenms/logs
/opt/librenms/logs/daily.log.6.gz
/opt/librenms/logs/daily.log.2.gz
/opt/librenms/logs/librenms.log.6.gz
/opt/librenms/logs/librenms.log.3.gz
/opt/librenms/logs/daily.log.4.gz
/opt/librenms/logs/librenms.log.4.gz
/opt/librenms/logs/librenms.log.2.gz
/opt/librenms/logs/daily.log.3.gz
/opt/librenms/logs/librenms.log.5.gz
/opt/librenms/logs/.gitignore
/opt/librenms/logs/librenms.log.1
/opt/librenms/logs/daily.log.1
and 1 more...
Right
root@librenms:/opt/librenms# ls -alrthv
total 2,6M
-rw-r–r-- 1 librenms librenms 549 juil. 9 10:01 webpack.mix.js
drwxr-xr-x 40 librenms librenms 4,0K oct. 1 10:48 vendor
-rwxr-xr-x 1 librenms librenms 5,8K oct. 1 09:36 validate.php
drwxr-xr-x 7 librenms librenms 4,0K oct. 1 09:36 tests
-rwxr-xr-x 1 librenms librenms 602 juil. 9 10:01 syslog.php
drwxrwxr-x+ 6 librenms librenms 4,0K juil. 9 10:01 storage
drwxr-xr-x 2 librenms librenms 12K oct. 1 09:36 sql-schema
-rwxr-xr-x 1 librenms librenms 8,7K juil. 9 10:01 snmp-scan.py
-rwxr-xr-x 1 librenms librenms 616 août 30 10:53 snmptrap.php
-rw-r–r-- 1 librenms librenms 791 juil. 9 10:01 snmpd.conf.example
-rw-r–r-- 1 librenms librenms 65 juil. 9 10:01 snmp.conf.example
-rwxr-xr-x 1 librenms librenms 14K juil. 9 10:01 services-wrapper.py
-rw-r–r-- 1 librenms librenms 563 juil. 9 10:01 server.php
drwxr-xr-x 5 librenms librenms 4,0K oct. 1 09:36 scripts
drwxrwxr-x+ 273 librenms librenms 12K oct. 10 17:42 rrd
drwxr-xr-x 2 librenms librenms 4,0K oct. 10 17:42 routes
drwxr-xr-x 5 librenms librenms 4,0K juil. 9 10:01 resources
-rw-r–r-- 1 librenms librenms 28 juil. 9 10:01 requirements.txt
-rwxr-xr-x 1 librenms librenms 845 juil. 9 10:01 renamehost.php
-rw-r–r-- 1 librenms librenms 480 juil. 9 10:01 readmegen.yml
-rwxr-xr-x 1 librenms librenms 6,1K août 30 10:53 poll-billing.php
-rwxr-xr-x 1 librenms librenms 14K juil. 9 10:01 poller-wrapper.py
-rwxr-xr-x 1 librenms librenms 15K juil. 9 10:01 poller-service.py
-rwxr-xr-x 1 librenms librenms 5,6K juil. 14 00:15 poller.php
-rwxr-xr-x 1 librenms librenms 857 août 30 10:53 ping.php
-rw-r–r-- 1 librenms librenms 1,2K juil. 9 10:01 phpunit.xml
-rwxr-xr-x 1 librenms librenms 3,8K juil. 9 10:01 pbin.sh
-rw-r–r-- 1 librenms librenms 1,1K juil. 9 10:01 package.json
-rw-r–r-- 1 librenms librenms 6,7K oct. 1 09:36 mkdocs.yml
drwxr-xr-x 2 librenms librenms 4,0K oct. 1 09:36 misc
drwxr-xr-x 176 librenms librenms 20K oct. 1 09:36 mibs
drwxrwxr-x+ 2 www-data www-data 4,0K oct. 10 17:42 logs
drwxr-xr-x 2 librenms librenms 4,0K juil. 9 10:01 licenses
-rwxr-xr-x 1 librenms librenms 1,7K juil. 9 10:01 librenms-service.py
-rw-r–r-- 1 librenms librenms 961 oct. 1 09:36 librenms.nonroot.cron
-rw-r–r-- 1 librenms librenms 490 juil. 9 10:01 librenms.cron
-rwxr-xr-x 1 librenms librenms 980 juil. 9 10:01 irc.php
drwxr-xr-x 9 librenms librenms 4,0K oct. 1 09:36 includes
drwxr-xr-x 12 librenms librenms 4,0K oct. 1 12:05 html
drwxr-xr-x 10 librenms librenms 4,0K oct. 10 17:42 doc
-rwxr-xr-x 1 librenms librenms 2,2K juil. 9 10:01 dist-pollers.php
-rwxr-xr-x 1 librenms librenms 14K juil. 9 10:01 discovery-wrapper.py
-rwxr-xr-x 1 librenms librenms 4,7K juil. 14 00:15 discovery.php
-rwxr-xr-x 1 librenms librenms 566 juil. 9 10:01 delhost.php
drwxr-xr-x 5 librenms librenms 4,0K juil. 9 10:01 database
-rwxr-xr-x 1 librenms librenms 11K août 30 10:53 daily.sh
-rw-r–r-- 1 librenms librenms 11K août 30 10:53 daily.php
-rwxr-xr-x 1 librenms librenms 876 juil. 9 10:01 cronic
drwxr-xr-x 2 librenms librenms 4,0K juil. 9 10:01 contrib
-rwxr-xr-x 1 librenms librenms 256 juil. 9 10:01 config_to_json.php
-rw-r–r-- 1 librenms librenms 1,8K juil. 9 10:01 config.php.default
-rw-r–r-- 1 librenms librenms 2,0K juil. 30 14:33 config.php.basic
-rw-r–r-- 1 librenms librenms 6,6K oct. 1 09:35 config.php
drwxr-xr-x 2 librenms librenms 4,0K oct. 10 17:42 config
-rwxr-xr-x 1 librenms librenms 1,8M sept. 27 14:44 composer.phar
-rw-r–r-- 1 librenms librenms 185K oct. 1 09:36 composer.lock
-rw-r–r-- 1 librenms librenms 3,3K oct. 1 09:36 composer.json
-rwxr-xr-x 1 librenms librenms 3,9K août 30 10:53 check-services.php
drwxrwxr-x 2 librenms librenms 4,0K oct. 11 00:20 cache
-rwxr-xr-x 1 librenms librenms 1,6K août 30 10:53 build-base.php
-rw-r–r-- 1 librenms librenms 53K juil. 9 10:01 build.sql
drwxrwxr-x 3 librenms librenms 4,0K août 30 10:53 bootstrap
-rwxr-xr-x 1 librenms librenms 6,2K juil. 9 10:01 billing-calculate.php
-rw-r–r-- 1 librenms librenms 1,7K juil. 9 10:01 artisan
drwxr-xr-x 10 librenms librenms 4,0K oct. 1 09:36 app
-rwxr-xr-x 1 librenms librenms 1,5K août 30 10:53 alerts.php
-rwxr-xr-x 1 librenms librenms 952 oct. 1 09:36 adduser.php
-rwxr-xr-x 1 librenms librenms 8,4K juil. 9 10:01 addhost.php
-rw-r–r-- 1 librenms librenms 11K juil. 9 10:01 README.md
-rw-r–r-- 1 librenms librenms 1,5K juil. 9 10:01 Makefile
drwxr-xr-x 14 librenms librenms 4,0K oct. 1 09:36 LibreNMS
-rw-r–r-- 1 librenms librenms 35K juil. 9 10:01 LICENSE.txt
-rw-r–r-- 1 librenms librenms 171 juil. 9 10:01 CONTRIBUTING.md
-rw-r–r-- 1 librenms librenms 92 juil. 9 10:01 CODE_OF_CONDUCT.md
-rw-r–r-- 1 librenms librenms 94 juil. 9 10:01 CHANGELOG.md
-rw-r–r-- 1 librenms librenms 11K juil. 9 10:01 AUTHORS.md
-rw------- 1 librenms librenms 962 oct. 9 11:43 .viminfo
-rw-r–r-- 1 librenms librenms 1,2K oct. 1 09:36 .travis.yml
-rw-r–r-- 1 librenms librenms 74 juil. 23 15:45 .selected_editor
-rw-r–r-- 1 librenms librenms 182 juil. 9 10:01 .scrutinizer.yml
-rw-r–r-- 1 librenms librenms 648 juil. 9 10:01 .mention-bot
-rw-r–r-- 1 librenms librenms 467 juil. 9 10:01 .gitignore
drwxr-xr-x 3 librenms librenms 4,0K oct. 1 09:36 .github
drwxr-xr-x 8 librenms librenms 4,0K oct. 10 17:49 .git
-rw-r–r-- 1 librenms librenms 73 juil. 9 10:01 .env.example
-rw-r–r-- 1 librenms librenms 232 juil. 28 00:15 .env
-rw-r–r-- 1 librenms librenms 340 juil. 9 10:01 .editorconfig
drwx------ 3 librenms librenms 4,0K juil. 12 17:35 .config
drwxr-xr-x 3 librenms librenms 4,0K juil. 10 00:17 .composer
-rw-r–r-- 1 librenms librenms 815 oct. 1 09:36 .codeclimate.yml
-rw------- 1 librenms librenms 1,1K oct. 9 14:29 .bash_history
drwxr-xr-x 4 root root 4,0K juil. 9 10:01 …
drwxr-xr-x 28 librenms librenms 4,0K oct. 11 11:13 .
#######config.php#######
