Graph not visible in Wireless tab
The problem
On the wireless tab, the graphs shows an error. All other graphs from the device is drawn perfectly.
This seems to be an issue with LibreNMS as multiple vendor devices has the same issue (MikroTik and Unifi tested).
The error message is not very visible:
Output of ./validate.php
LibreNMS  | 23.11.0 (2023-11-25T20:17:34+01:00)
DB Schema | 2023_11_04_125846_packages_increase_name_column_length (273)
PHP       | 8.1.22
Python    | 3.10.13
Database  | MariaDB 10.5.23-MariaDB-1:10.5.23+maria~ubu2004
SNMP      | 5.9.3
[OK]    Installed from the official Docker image; no Composer required
[OK]    MySQl and PHP time match
[OK]    No python wrapper pollers found
[OK]    Redis is unavailable
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
[OK]    rrd_dir is writable
[WARN]  Updates are managed through the official Docker image
What was the last working version of LibreNMS?
No response
Anything in the logs that might be useful for us?
No response
Related issue on Github: Graph not visible in Wireless tab · Issue #15761 · librenms/librenms · GitHub
You should probably click on one of the graphs and click show command to view the entire error message.
If I had to take a wild guess, it is a file permissions issue.
Thank you, I was not aware of this button!
Now I see the error message:
ERROR: opening '/data/rrd/10.0.14.20/wireless-sensor-clients-unifi-Wifi1.rrd': No such file or directory
Indeed looks like some permission error, but I don’t know why.
Permissions seems correct for all folders, also as I said, other types of graphs work correctly.
I checked and the folder 10.0.14.20 is there, it has all the other rrd datafiles in it, but this one is not there actually
If I create the file manually and setting the correct ownership (librenms:librenms) I get a different error:
ERROR: mmaping file '/data/rrd/10.0.14.20/wireless-sensor-clients-unifi-SsidName.rrd': Invalid argument
Any idea for this? I checked usual issues.
I still did not find the solution for the problem below
Problem was that Wireless module polling was disabled. After enabling, it works correctly.
