I am experiencing issues with the device and ports graphs in LibreNMS, none of the graphs are displaying anything and the In and Out values show a “-nan” error, as shown below.
Has anyone encountered a similar issue?
I’m running the latest LibreNMS Docker container, version 24.8.0 Sun, Aug 25, 2024.
I checked the librenms.log file and found the following messages. Could these be related to why the graphs aren’t working?
librenms:/opt/librenms/logs# cat librenms.log
Next Illuminate\Database\QueryException: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'librenms.config' doesn't exist (Connection: mysql, SQL: select
* from `config` where (`config_name` = device_display_default) limit 1) in /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:795
Stack trace:
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(755): Illuminate\Database\Connection->runQueryCallback()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(424): Illuminate\Database\Connection->run()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2748): Illuminate\Database\Connection->select()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2736): Illuminate\Database\Query\Builder->runSelect()
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3290): Illuminate\Database\Query\Builder->Illuminate\Database\Query\{closure}(
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2737): Illuminate\Database\Query\Builder->onceWithColumns()
#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(720): Illuminate\Database\Query\Builder->get()
#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(704): Illuminate\Database\Eloquent\Builder->getModels()
#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Concerns/BuildsQueries.php(296): Illuminate\Database\Eloquent\Builder->get()
#9 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(549): Illuminate\Database\Eloquent\Builder->first()
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(583): Illuminate\Database\Eloquent\Builder->firstOrNew()
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Traits/ForwardsCalls.php(23): Illuminate\Database\Eloquent\Builder->updateOrCreate()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2333): Illuminate\Database\Eloquent\Model->forwardCallTo()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2345): Illuminate\Database\Eloquent\Model->__call()
#14 /opt/librenms/LibreNMS/Config.php(262): Illuminate\Database\Eloquent\Model::__callStatic()
#15 /opt/librenms/LibreNMS/Config.php(460): LibreNMS\Config::persist()
#16 /opt/librenms/LibreNMS/Config.php(61): LibreNMS\Config::processConfig()
#17 /opt/librenms/app/Providers/ConfigServiceProvider.php(27): LibreNMS\Config::load()
#18 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Providers\ConfigServiceProvider->boot()
#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod()
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call()
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1006): Illuminate\Container\Container->call()
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(987): Illuminate\Foundation\Application->bootProvider()
#25 [internal function]: Illuminate\Foundation\Application->Illuminate\Foundation\{closure}()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(988): array_walk()
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/BootProviders.php(17): Illuminate\Foundation\Application->boot()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(261): Illuminate\Foundation\Bootstrap\BootProviders->bootstrap()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(447): Illuminate\Foundation\Application->bootstrapWith()
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(199): Illuminate\Foundation\Console\Kernel->bootstrap()
#31 /opt/librenms/app/Console/Kernel.php(66): Illuminate\Foundation\Console\Kernel->handle()
#32 /opt/librenms/lnms(39): App\Console\Kernel->handle()
#33 {main}
PDOException: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'librenms.config' doesn't exist in /opt/librenms/vendor/laravel/framework/src/Illuminate/D
atabase/Connection.php:416
/opt/librenms $ ./validate.php
LibreNMS | 24.8.0 (2024-08-25T23:45:45+02:00)
DB Schema | 2024_07_19_120719_update_ports_stack_table (296)
PHP | 8.2.20
Python | 3.11.9
Database | MariaDB 10.5.26-MariaDB-ubu2004
RRDTool | 1.8.0
SNMP | 5.9.4
[OK] Redis is functional
Any help would be greatly appreciated! Thank you!
