Hi, we migrated data from observium years ago and the rrd files which have a size of 1739144 bytes do not display the port graphs correctly, as soon as some threshold is crossed the graph is only plotted up to some value.
The newly created rrd files have a size of 2543768 bytes.
Is there any way to fix the rrd files to keep the original values and not have to make all from scratch, thus losing the historical graphs even if not all are plotted correctly?
Thank you
