I’m having issue displaying logs from Graylog 4 in Librenms, I can perform the API call to Graylog from the Librenms server but all that is returned is the below:
curl -4 -X GET -u “admin:**********” -H ‘Accept: application/json’ ‘http://graylog.somedomain.com/api/?query=*&range=&limit=25&offset=0’ | python -m json.tool
“cluster_id”: “8038703b-3f98-4339-b35e-2465f4de1ceb”,
“node_id”: “75fda305-cf1c-4958-ac85-d3978a738352”,
“tagline”: “Manage your logs in the dark and have lasers going and make it look like you’re from space!”,
“version”: “4.0.1+6a0cc0b”
Am I missing something in Graylog I have multiple inputs that have multiple streams, that remove the messages from all messages. Thanks
