my step to install librenms.
- open PVE shell
- mkdir librenms
- cd librenms
- Create 3 files
root@pve:~/app/librenms# ll
total 20
-rw-r--r-- 1 root root 2961 Apr 6 16:17 docker-compose.yml
-rw-r--r-- 1 root root 291 Apr 6 16:16 librenms.env
-rw-r--r-- 1 root root 204 Apr 6 16:17 msmtpd.env
5. docker-compose up -d
6. open [http://ip:8000](http://ip:8000/) should see librenms's login UI.
http://192.168.152.100:8000 have nothing to display, and no error messages display.
I try to test it using curl, result like this:
root@pve:~/app/librenms# curl [http://192.168.152.100:8000](http://192.168.152.100:8000/) -v
* Expire in 0 ms for 6 (transfer 0x55e9cccd0fb0)
* Trying 192.168.152.100...
* TCP_NODELAY set
* Expire in 200 ms for 4 (transfer 0x55e9cccd0fb0)
* Connected to 192.168.152.100 (192.168.152.100) port 8000 (#0)
> GET / HTTP/1.1
> Host: 192.168.152.100:8000
> User-Agent: curl/7.64.0
> Accept: */*
< HTTP/1.1 200 OK
< Server: nginx
< Date: Tue, 06 Apr 2021 08:33:29 GMT
< Content-Type: text/html; charset=UTF-8
< Transfer-Encoding: chunked
< Connection: keep-alive
< Keep-Alive: timeout=10
< Vary: Accept-Encoding
* Connection #0 to host 192.168.152.100 left intact
My Configuration is:
* Docker version (type `docker --version`) :Docker version 20.10.5, build 55c4c88
* Docker compose version if applicable (type `docker-compose --version`) : docker-compose version 1.21.0, build unknown
* Platform (Debian 9, Ubuntu 18.04, ...) :
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
* System info (type `uname -a`) : Linux pve 5.4.44-1-pve [#1](https://github.com/librenms/docker/issues/1) SMP PVE 5.4.44-1 (Fri, 12 Jun 2020 08:18:46 +0200) x86_64 GNU/Linux
* Include all necessary configuration files : `docker-compose.yml`, `.env`, ...
Just copied from https://github.com/librenms/docker/tree/master/examples/compose. Only modifyied version: "**3.3**"
Docker info
root@pve:~/app/librenms# docker info
Client:
Context: default
Debug Mode: false
Plugins:
app: Docker App (Docker Inc., v0.9.1-beta3)
buildx: Build with BuildKit (Docker Inc., v0.5.1-docker)
Server:
Containers: 13
Running: 7
Paused: 0
Stopped: 6
Images: 7
Server Version: 20.10.5
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
Logging Driver: json-file
Cgroup Driver: cgroupfs
Cgroup Version: 1
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: inactive
Runtimes: io.containerd.runc.v2 io.containerd.runtime.v1.linux runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 05f951a3781f4f2c1911b05e61c160e9c30eaa8e
runc version: 12644e614e25b05da6fd08a38ffa0cfe1903fdec
init version: de40ad0
Security Options:
apparmor
seccomp
Profile: default
Kernel Version: 5.4.44-1-pve
Operating System: Debian GNU/Linux 10 (buster)
OSType: linux
Architecture: x86_64
CPUs: 3
Total Memory: 2.861GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Registry: https://index.docker.io/v1/
Labels:
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
WARNING: bridge-nf-call-iptables is disabled
WARNING: bridge-nf-call-ip6tables is disabled
