Help me to install new os
Hi folks. Im new on LibreNMS and i have configured and installed correctly the system. I have added snmp device like switch (Juniper Cisco ) and some other network device. Im working in TV and i need to monitor some device like Elber Microwave for example or encoder and decoder that support snmp protocol. But when i add on the system they are generic device and not showing any graphs or information that i need to monitor. I have mibs for that devices. I have read the insctruction to add a new OS but is not clear to me… Can you help me with more information how to add a new os for new devices and how to monitor them? I need a more simple manual or info for this.Thnx
@Andi_Andu1
If you cant add by yourself using https://docs.librenms.org/#Developing/Support-New-OS/ it will be hard to explain you step by step.
Take a look to https://docs.librenms.org/#Support/FAQ/#what-information-do-you-need-to-add-a-new-os and maybe someone else can help you out but that will take a very long time.
Try to do it by yourself, join Discord for support on adding it but you will have to do most of the job.
OK Thnx :smile:
