Help on how to enable Routing tab
Hello guys, i need some help on how can i enable the routing tab in here: photo3
can anyone help me thru this? thanks.
can anyone help me?
Hi @arvinalucitain
Routing table will appear if (and only if) there is routing data collected (OSPF, BGP, VRFs etc etc). So you can enable discovery/poller modules related to routing protocols, and that will make the menu appear if any of them returns data.
