I am new to this and I have some problems with sending traps via snmpv3 from a brocades to librenms, everything works correctly for v2 but the problem is that I can only send traps via v3 if I put the -e flag and indicate the engineid of the user that I have created but the problem is that I cannot put that engine id in the brocades since I create one type 0x0000 and the brocades only accepts 00:00:00, can someone tell me how to do it without the engineid or how I can make this work by v3.
| Version | 23.1.1 - Thu Feb 09 2023 20:33:37 GMT+0100 |
| Database Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248) |
| Web Server | |
| PHP | 8.1.15 |
| Python | 3.10.10 |
| Database | MariaDB 10.5.16-MariaDB-1:10.5.16+maria~focal |
| Laravel | 8.83.27 |
| RRDtool | 1.7.2 |
