1112
6 November 2017 11:38
1
Hi!
There is a task to connect the device Uniping server solution v3 / SMS to LibreNMS to receive data from temperature, humidity sensors and so on.
Exchange is performed using SNMP v.2 protocol
link to devices http://www.netpingdevice.com/products/uniping-server-solution-v3-sms
The output of ./validate.php:
Component
Version
LibreNMS
1.32-70-g0f8966a
DB Schema
211
PHP
7.0.22-0ubuntu0.16.04.1
MySQL
10.0.31-MariaDB-0ubuntu0.16.04.2
RRDTool
1.5.5
SNMP
NET-SNMP 5.7.3
Steps to reproduce an issue.
If it’s an issue with the WebUI then please consider including the browser version you are using.
I’m guessing the device OS in LibreNMS is showing a Generic OS?
opened 01:28PM - 06 Nov 17 UTC
closed 03:46PM - 20 Feb 18 UTC
Device
DO NOT DELETE THIS INFORMATION.
> Please read this information carefully.
… GitHub issues is for known/validated bugs, please do not post issues asking for help or how to do X, Y or Z.
You can use our [Discord server](https://t.libren.ms/discord) to ask questions or our [community site](https://community.librenms.org).
If you have a feature request please post this on our [community site](https://community.librenms.org/c/feature-requests).
Please confirm each of the sections below by putting an `x` in the box like `[x]`.
- [ x] Is your install up to date? [Updating your install](http://docs.librenms.org/General/Updating/)
Please do not submit an issue if your install is not up to date within the last 24 hours or on a stable monthly release.
- [ x]Please include all of the information between the `====================================` section of `./validate.php` which you can run from the cli.
- [x] Please provide ALL info asked for [here](http://docs.librenms.org/Support/FAQ/#faq20).
- [x] Please provide as much detail as possible.
- [x] Please do NOT post more than 10 lines of debug information here, use a pastebin service or GitHub Gists.
Love librenms? Please consider supporting our collective:
👉 https://t.libren.ms/donations
Hi!
Device - http://www.netpingdevice.com/products/uniping-server-solution-v3-sms
MIB - http://www.netping.ru/Pub/Firmwares/[Pub]%20DKSF%2070.6.6%20MB.mib
LibreNMS | 1.33-39-g21495a8
DB Schema | 215
PHP | 7.0.22-0ubuntu0.16.04.1
MySQL | 10.0.31-MariaDB-0ubuntu0.16.04.2
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
Discovery.php - https://p.libren.ms/view/6ec607fb
Poller.php - https://p.libren.ms/view/3745676d
snmpbulkwalk - https://p.libren.ms/view/4e3d03b5
I apologize for the inconvenience.
1112
6 November 2017 14:21
3
Yes, as a Generic device is determined.
But the information from the sensors does not display.
In the “Observium” system, there is support for NetPing devices.
We also need to get the data in LibreNMS.
yes, you won’t see any sensor since the device os has not been added into LibreNMS. Please go back to the Github issue you left out info that is needed.
thank you -
Device
Hi!
DB Schema | 215
RRDTool | 1.5.5
