I am not able to use Transit + Peering function of LibreNMS now. What should i configure or install any plugins to use the function Peering + Transit to view BGP sessions with Mikrotik Routers?
You missunderstood how it works.
Transit and Peering are Port (interface) types and has nothing to do with BGP Sessions.
For example, lets say you have your transit link in port 1, and your peerings in port 2 and 3.
What you have to do is to name your port 1 interface to something like:
Transit: yourdescripcion
and your peering ports to:
Port 2 to Peering: Google
Port 3 to Peering: Netflix
You can add more variables, check: https://docs.librenms.org/Extensions/Interface-Description-Parsing/
